I'm not sure this applies. His is a 2009 and the recall ended 5 years earlier. But it's still something to consider.Here is a posting of well known suspension issues with your model
Important Safety Issue: Monaco, HR & Safari Chassis
I have a 2003 Holiday Rambler Ambassador that had two recalls for suspension concerns in 2005. The recall included 2002, 2003 and some 2004 Monaco Knight, Cayman, HR Ambassador, Neptune, Safari Cheetah, Sahara and Zanzibar models.A few days ago I was driving my RV on Interstate 80 near Sacramento...community.fmca.com
The steering boxes on these Class A RV's are notorious for having a lot of "slop" in them. Lots of play from side to side. The TRW box is adjustable. The Shepherd M100 is not adjustable. You should determine which box you have. If you see a place on the side of the box to loosen a nut and turn a slotted post with a screw driver then it's probably the TRW. If it's the Shepherd M100 you may just have to live with it because it you have it replaced the new one may be just as bad. Make sure your front end alignment is good. This will add to the problem!We just bought a 2009 holiday rambler 30 ft , it does have steering suspension and the front and back shocks, but driving it home , it was hard to keep on the road, any suggestions ?
After a quick search, EZ as you indicated above, the steering box is notorious for issues.The steering boxes on these Class A RV's are notorious for having a lot of "slop" in them. Lots of play from side to side. The TRW box is adjustable. The Shepherd M100 is not adjustable. You should determine which box you have. If you see a place on the side of the box to loosen a nut and turn a slotted post with a screw driver then it's probably the TRW. If it's the Shepherd M100 you may just have to live with it because it you have it replaced the new one may be just as bad. Make sure your front end alignment is good. This will add to the problem!
Man I hate it for them. That's an expensive repair. But with the box on my coach weighing 95 pounds I didn't think I could hold it up while lining up the bolt holes and starting the bolts when putting it back together. So, I'm paying a shop to do it. They said it would take 10 days. It's been 3 weeks so far and I haven't heard a word from them..........BTW on this Forum within the last hour a member posted about his leaking steering box.
