Storage Door - Latches - The dreaded cable latch issue
Old-RV'er
RVF Expert
Blairsville, GA
Ventana 3407
34'10"
2013 Jeep Wrangler Sahara Unlimited
All - Today, leaving RV Camping Park, and the services bay door refused to latch. Realize that cable which controls latch "locking" has released. My question is I read thread couple years ago on rhe fix. But searching for it sends me to other things which have no relationship to this issue. Would like to fix this tomorrow if possible, after the rest of the grass cutting. So if anyone can point me in the right direction, would be deeply appreciated. Door is not held shut with electrical tape, wrapped around the exhause pipe stanchoin but not good for security and rodents. Thank you in advance.
It could be a few different things. Best to just pop the black plastic cover plate off and inspect. I’ve had it where the top part of the electrical plunger just popped off the head unit, easy fix. The plunger itself could have failed, the cable could have come loose, etc. It’s a very simple setup, just remove the cover and take a look.
Thank you, on tomorrows agenda after final yard work.
Yard work. I do not miss that.
Turns out not the cable, bakelite support is broken, pin shered off and top part of locking mechanism is broken. Bent pieces back, and now it is lockable. Need to replace this part pictured. I have attached, pictures of a non broken unit and the broken one for comparison. Will Call Newmar on Monday. Suspect door might not be lining up all the way. Once new part ordered and received, will see if I can raise the door so it is closer to level. This is the services bay door, and it lead time is long, will take a good one off another door not used as much, and put bad one on that door. Hopefully the lead time won't be long. Better half is getting tired of all the little things going wrong each trip.
I need the same part. Left a message with Newmar Friday after hours.
Would appreciate the part number if you have it.
Seems to be a common issue for that top plastic part to sheer but I don't think it plays any roll in the locking/unlocking. I could be wrong but I think it's just a matter of the cross bar hitting the U hook latch properly. I dunno
This is due to the newmar instance that bay doors need to slam shut.
All my doors can close without a slam, and most with a pinky finger. If a door needs to slam, then it needs to have the latch adjusted. It's very time consuming, but slamming things will eventually break something.
So, one only needs to adjust to get rid of the bone jarring slamming? I’m on it.
Don’t slam your doors. Just press with your hand the door where the latch is located. If the U part attached to the coach frame is misaligned, it will brake the plastic guide eventually.
What I do is get a low stool and sit where I can get eye level with the latch. Pushing it slowly. Determine if it is trying to push the door up or down. Adjust the bracket, without fully tightening, and repeat. Once you find the proper vertical placement, then check for horizontal.
The amount of compression a new seal will allow vs an older will affect the horizontal adjustment. This will change over time, and should always require a small amount of force to compress. There is a lot of seal surface area compared to the weight of the door.
I am sure this is where the bad advice of slamming originated. For me, two fingers will provide enough force to close the doors securely.
The front door is very heavy, so all I need is a pinky to get it to close fully. Never slam the entry door...things will wear out and break.
The adjustment for that latch is very different. I will have to find the guide for that door.
Will have to try this. Never was comfortable with the slamming idea.
Hey Mr. Buly. I just tried that and it works. I am sure my neighbors will appreciate this technique, as well.:giggle:
Do not have part number. Yes, bakelite part is mostly a guide, but the pin keeps the two metal pieces together, and they need the support so the lock does not deform. If I get PN from Newmar I will post here. Might buy extra if not to expensive and the battery access/DEF-Hose Storage doors do not have exactly the same mechanism on the door if memory serves. Will advise once know.
Tha black plastic latch guide is not made of Bakelite. I think it is high density polypropylene? They should have made them from Delrin, but I guess it will cost few cents more. Car latches have Delrin parts and they last forever.
I get up early around 5-6 am, so that’s how it started. Did not want to wake up the neighbors if needed something from the basement, or had to dump the tanks ?
Newmar Parts, $63.00 and change, should be here by Friday. Latch has some redesign, expensive part is the nylon support/guide thing. There is a left and right side part number. I will attach the document from Newmar. Very excellent service. Lots of supply on this part.
  • rotary latches.docx
Its a money maker--as it is usually the first to break when being slammed into the metal catch.
Win - Win for RV service and parts sales. No time wasted fixing the problem, and a new profit center.
The rotary latches are made by Eberhard. $10-$15 retail. I had them installed on my plane. Still have some left?.
I just attempted this technique. It works on my entry door, but the others are mocking me to the point of affecting my posture.
Received Part today. Going to install tomorrow, will try to remember to take pictures of any gotchas, so you have a record. Does not look like rocket science. I never observed any tension on the cable for the lock, so not sure why it would ever come lose.
