- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Soon...very soon.
Is there a way to track this and/or get directions on making one?
Soon...very soon.
This only works if you have a manual transmission. Without the speed sensor connected the transmission will not shift gears. It’s been tested on motorhomes and did not work.In looking for DEF head alternatives so we are prepared in a failure, ran across a post from a OTR driver who found a temporary solution to avoid needing a tow.
Disconnect the speed sensor at the drive shaft.
Yes, as the driver you no longer know your speed, but more importantly, the computer doesn’t know your speed either. For his OTR trucks this has allowed him to keep going and avoid a tow.
Going to crawl under our rig so IF we have a derate I can try this 5 min temporary fix.
Still following these other alternatives too.
Thank you, good to know.This only works if you have a manual transmission. Without the speed sensor connected the transmission will not shift gears. It’s been tested on motorhomes and did not work.
