Question Thor: No water
Donkey
Thor Motor Coach: F450 v10, 2017. Can someone tell me hours to access water pump? With switch on, I can hear it but there doesn’t seem to be any way to get to it. I think it’s located horizontally between the fresh water tank and shower. Refer to photos with red indications where I’m guessing water pump is located.
It should be located near the fresh water tank. Do you know where the tank is located? Try removing panel under the frig and looking for pump there.
I think if you remove panel under the frig you should be able to locate the water pump
Found it ?
ref picture. Red indicates location of water pump. Above that is the heater/LP furnace. Below that is storage. Storage is secured with screws and foam gap sealer. So, they intended for us to remove the storage container and then cut hole in floor to access this water pump? ?
This is underneath water pump
Arrow here indicates 2 x 6 block holding up furnace. I wonder if I can remove that block to access pump ?
You said you can hear the pump running? I would make darn sure its not a kinked or plugged inlet to the pump before I go that deep. Do you have a control valve for City/onboard water?
