Resolved Tiffin Red 33AA water pump
Headhunter
Northeast PA
Tiffin
Phaeton
38ft
Powerglide
Cummins 450
2017 Jeep Sahara
My water pump is not working correctly. My water pressure coming out of the faucets and shower is very low. Usually when I turn the pump on it makes a whirring sound and shuts off. When I turn it on there is no noise.
Can a water pump have a breaker? I checked the breakers on DS lower bay everything looks good. Also the breakers in the cabinet next to bathroom. Nothing that says water pump on it?
Can Freightliner replace a water pump for me if needed?
HH
Have you checked your house filter to make sure it's not clogged? When is the last time you replaced it?
No, I don't think FL will replace the water pump as that's on the house side, not chassis. I've replaced mine before, it's not hard.
Yeah, I just put in a new water fliter a couple of weeks ago. But I will pull it again and check it out. The removal looks straight forward, and I could get the pump from Tiffin Parts, it's the electrical hook up that sort of worries me.
HH
HH
It's a straight forward 12V red/black wire connection, unless the problem lies elsewhere.
Ok I will take a look at it. Someone suggested it may be a clogged aerator ????? Where is that located?
HH
They typically unscrew at the output of the faucet itself.
Solved: Duhhhhh my shower head has a shower miser that I never knew existed. It turns on and off by a bar t
Good to go.... thanks for the help.
HH
