Question Tire Air pressure Source
I'm probably in the minority, but I do use the coach's air to top off my tires. It takes a few minutes per tire, but I can get the fronts up to 115 psi which is where I want them. The backs are less and thus easier to top off.
Has anyone tried using nitrogen in there tires on these rigs.
Yes, I have been using nitrogen in everything I own. I purchased a tank to try the nitrogen in everything I own. :confused: I personally think it is in my head, ;)but it seems the coach does less rut tracking and wandering.
Nitrogen v air!
I've used nitrogen in racing applications for decades. It does have its purpose. One of my firstclass A (long ago), a 40', had a LF tire blowout. The coach was only 3 yrs old. What I learned was, the moisture inside the tire will rotten the side wall, hence, cause the side wall blowouts.
Some service stations do not maintain their air compressors properly. Those compressors tend to introduce significant amount of moisture into your tires. You can test this by simply opening the valve on the air line and spray into the air. Those compressors that are maintained poorly, you will see a stream of moisture come out of the air hose.
For most cars and trucks that are driven on daily basis, this is not a major issue. However, for an RV that sits idle for many months, that becomes a cancer. The moisture inside the tire collects at the bottom and overtime it rusts the belts on the side from within. Eventually, you'll experience a side wall blowout.
That first blowout, was my last tire blowout. That was some 20 yrs ago. Since, I started using nitrogen. I do not replace the entire existing air inside the tire with nitro. I just use the nitro tank to add air when needed. There is no reason to replace the entire air volume, unless you plan to race that vehicle. The idea is to avoid introducing more and more moisture into the tire for a vehicle that tends to sit idle for long periods of time.
The tanks that I use cost about $50 to replace/refill. I don't recall how much it cost to purchase the original tank. Its a 5' tank. Without using it for racing it lasts me about 3 yrs. That covers the 8 tires for the motorhome, 4 for the personal car and 4 for the tandem axle trailer in tow.. With that approach, I have never had any more tire blowouts, and my rv tires last 8-9 years without any issues. Attached is the drive axle tires which were just shy of 7 yrs old and more than 70k. If you look close, you'll see there is very little thread left in them. Unlike my previous units which were kept in a climate control barn, this one was outside the entire time and with exposure to extreme hot andextreme cold.
Btw, those drive axle tires worn out much sooner that I expected them. Thats was due to the defective tag axle which could not be aligned properly, hence causing excess wear on the drive axle tiers as well. The drive axle was originally slightly outof alignment due to faulty freightliner alignment procedures, otherwise, those michelin's should have lasted well into 80-90kmiles.
With a little proper care, the RV tires can last as long as they are designed to be used. Also, anapplication of 303 twice a year, seemed to help.
So as the article states the atmosphere has roughly 80% nitrogen. Those places like Costco that fill with nitrogen, have nitrogen generators.
The advantage that comes to mind according to my research on the subject was only touched in the article.
The static created within the tires while you go down the road creates Ozone. Ozone is destructive to rubber. (Filling with nitrogen eliminates checking from the inside of the Tire). .
As the oxygen seeps through the Tire because of the pressure, the tire actually works as a nitrogen concentrator(generator), over time all the oxygen will seep out of the Tire leaving nitrogen and moisture. That is the reason for topping off tire pressure, by the way! It is also why you should be separating the moisture/oil from your compressor.
Using the tire for this purpose however oxidizes the carcass of the tire, so is detrimental to the tire life.
Thinking about picking up a tank of Nitrogen for the garage. Simple enough to top off between trips. If there is going to be large changes in elevation or temps, I'll just add a little bit for the on road changes...
When we ordered the Newmar DSDP, I added a front air chuck located in the generator pull out area. My thinking is it would be nice to have an external air source for tires and other momentary uses. If the engine is running or not?
Am I correct in thinking that the on board air pressure reserve can be used to top off tires? Or will I still need to drag around the Viair compressor?
I do have an air hookup in our basement from the factory. It does a good job of airing up my tires. I do have the engine running when ever I do this. I do believe this is from the compressor for the air bags as well.
