Ok thank you. Also the lug nut torque is all over the place. One says 100 other says 145 and one says 450!!! What would you recommend?Look up the tire weight chart. Get coach weight and adjust accordingly. I run 97.100lbs.
97.100 - that is pretty preciseLook up the tire weight chart. Get coach weight and adjust accordingly. I run 97.100lbs.
It really depends on you coach and rim/tire sizeOk thank you. Also the lug nut torque is all over the place. One says 100 other says 145 and one says 450!!! What would you recommend?
Yup, changes with temp.97.100 - that is pretty precise![]()
