Tire pressure question
jriker63
New tires installed today. PSI label on new tires say 120 psi. Tire guys said to inflate to 100 psi, rv Manuel says 80 psi. What psi should I run. 2005 fleetwood bounder 34f. Thanks in advance!
Look up the tire weight chart. Get coach weight and adjust accordingly. I run 97.100lbs.
That I dońt know.I leave that to the tire shop.
Ok thank you. Also the lug nut torque is all over the place. One says 100 other says 145 and one says 450!!! What would you recommend?
It really depends on you coach and rim/tire size
