Matt
- Jan 25, 2021
- Glasford, IL
- Forrest River
- Cedar Creek 311RL 5th Wheel
- 35'
- F350 Super Duty
I can not understand it for you. I can only state what I have said.ok so what you're saying is that using the max tire pressure on the tire is a safety issue? Not true.
The recommended tire pressure is on the sticker from the Mfg., it's on the trailer. My previous RV was a 2012 Laredo where the load rating on the tire was 'D'. Those D rating tires came with a max tire pressure of 65 lbs and the sticker said to use 65lbs of pressure. When I looked at the loaded weight of my RV the weight of everything basically put these tires at the max. It was still legal for the Mfg to do that but in the middle of August going down the highway in the heat at full weight made me nervous. I decided to upgrade the tires to a load rating of 'E' which basically means they can handle more weight. Same size tire just a higher load rating. Those 'E' rating tires I put on had a max pressure of 80lbs giving me less stress (my blood pressure) going down the road so obviously I wasn't going to set those tires to 65lbs. Use your common sense.
As I mentioned already, I have a 20 year track record doing it this way with ZERO blow outs. You do it your way.
False.And I'll add one more thing to think about; Trailer tires are only rated and tested at 65mph. You can weigh your rig and play around with tire pressure till the cows come home but if your going faster that 65mph you can throw your calculations out the window and wait for your blowout.
Actually, when I took the Spartan Owners Course, they said overinflated tires can reduce traction, as well as reduce braking ability and handling. As you can see from the photo that @redbaron shared you can see the excessive wear in the center when overinflated. When riding on the center section of the tread, debris can move the tire around, not to mention it is an uncomfortable ride.ok so what you're saying is that using the max tire pressure on the tire is a safety issue? Not true.
WRONG! Different tires have different "speed ratings"!And I'll add one more thing to think about; Trailer tires are only rated and tested at 65mph. You can weigh your rig and play around with tire pressure till the cows come home but if your going faster that 65mph you can throw your calculations out the window and wait for your blowout.
Oh, and some on here have significantly greater than a 20 year track record!ok so what you're saying is that using the max tire pressure on the tire is a safety issue? Not true.
Are you suggesting that one could do something for 30+ years, and have always done it wrong? How is that possible--doesn't seniority and experience automatically make it the right way?Oh, and some on here have significantly greater than a 20 year track record!
And Yes, WE WILL DO IT OUR WAY, & BE SAFE at the same time!
Good Luck, & hopefully, Good RV'ing!!
