That sounds great, and should be plenty stout, my concern would be the actual hitch mount on the motormome, your work may be good for 25,000 lbs, but if the motorhome hitch is only rated for 5,000 lbs where does that leave you ?
thanksHere is a link to Roadmaster’s website using your 2021 Ram. It gives you everything you need to consider: baseplate, tow bar, lights. Battery disconnect, etc.
BlueOx and Roadmaster are the leaders in what your looking for and both will provide excellent support. You can build your own baseplate but they already have.
I'd like to offer some clarification here: Sahara and Rubicon are packages available on the Jeep Wrangler, and the Jeep Gladiator, not separate models, although many people think of them as separate models. And the 4WD gearbox is not a transaxle, but rather a transfer case.A good example is any Jeep Wrangler, Sahara, or Rubicon, two door or 4 door. First on newer models there is NO steering lock. On your 4 wheel shifter you shift your trans-axle in Neutral. This disengages your transmission from your drive axles. Once in neutral you can shift your regular auto shifter in drive or reverse and you vehicle will not move. Then shift into park and shut off your engine.
Told by who? Dealerships and owners manuals would be a good source.I am being told that both can be flat towed, but neither can be towed with the front wheels on a dolly ( that doesn't make sense to me)
It is a viable optionDoesn't it make a bit of sense to use a vehicle trailer? One with ramps as opposed to a flat trailer and one that has a tilt frame for easy loading and unloading. There was one parked next to us last year at the campground. The concern then would be the combined weight of the trailer and vehicle, trailer brakes, and controller on the tow vehicle which are present as used on the boat trailer. Seems like the minimum hassle and has no concern about towing flat or otherwise.
EZ did you install the Air Force One yourself? ThanksI used to tow a Ram 1500 4wd with my Blue Ox tow bar until I sold it. If your Ram 1500 is 4wd you can flat tow it with ease. I now tow my wife's Jeep Grand Cherokee Trailhawk 4wd. It also has the electronic transfer case since it is 4wd. I can't even tell either one is back there without looking at the back up camera. Not sure about you Jeep Compass. But if you have the electronic transfer case that can be put into neutral by pressing a button then you should be good to go. But if it was me I'd flat tow the Ram 1500 so you could be more comfortable when you had to drive it. LOL.
I also bought an Air Force One auxillary braking system so if my truck or Jeep ever come loose they won't kill another family when they crash into them at 65 MPH. Lots of people don't use them but I couldn't sleep at night after killing someone's kids because I wanted to save a few bucks.
No. I paid a local company to do it for me. They did a very good job. I travel a lot for my job and just didn't have the time to do it myself although I normally do all my own work on my vehicles.EZ did you install the Air Force One yourself? Thanks
And a rv brake so the Ram’s brakes will work when the rv brakes are applied.So lets say that the Compass is out and i tow my ram ( its on the list of 20 best vehicles)
can I assume that all i need is a tow bar and magnetic light kit.
