Good point, Kevin. I could accept the dealership installing the trailer connection in the truck bed.I would have the electrical done by dealer and hitch done by a hitch pro. My reasons are I would not want to talk to FORD about electrical problems unless they caused them.
Thanks for that information. It has been a while since we towed a 5th wheel or bought a truck to do so. If that’s the “prep package” the OP is talking about, then it sounds like it might be a good option. A good hitch shop, however, will do pretty much the same thing (though, as you point out, it may require some disassembly) and they can tailor their “prep” to the specific hitch you will be using.I am going to assume that the OP is referring to the factory 5th wheel prep package, which is the under-bed frame-mounted plate with the pucks for a removable puck-style 5th wheel hitch, as well as the inside-the-bed 7-pin trailer connector.
All of the big-three truck brands sell the prep packages for post-delivery installation.
The kit comes with a plug-and-play harness for the bed-mounted trailer plug, so no real "electrical work" is involved, just unplugging the place in the truck harness where the new pigtail goes, inserting the new harness, and plugging back together.
The drawbacks I see with this situation are these:
1. When built at the factory, a truck being equipped with the 5th wheel puck system would also be outfitted with the heavy duty towing package for that particular model of truck. One must verify what towing setup is on the truck they plan to have the 5th wheel prep package installed on to make sure it is ready for 5th wheel duty. If it already has the factory in-dash brake controller, and a 2-1/2" receiver hitch in back with a bumper-mounted 7-pin connector, it probably has all of the trans cooling and heavy duty radiator, etc.
2. When the factory installs the 5th wheel prep package, they install a bed that has the holes for the pucks already punched out prior to that bed being primed and painted, so those holes are properly treated to prevent rust. As an after-delivery installation, those holes have to be cut with a hole saw, leaving raw metal exposed on the edges of the holes. They get covered up with the plastic donuts that go in the holes, but they are still raw metal exposed underneath. The same applies to where they must hole-saw the place for the in-bed 7-pin receptacle. On a Ford with aluminum bed it may not matter a much as with a steel bed that can rust around those cutouts.
3. The bed has to be removed or unbolted and raised off the frame far enough to install the frame-mounted plate and brackets of the prep package. This is a risk (though not a big one) of the bed getting dinged or the back of the cab getting scratched by the bed movement. Some have to move back before up to avoid lower cab contact.
I studied all of this when truck shopping in 2020, and was considering doing my own "prep package" install if I couldn't find the right truck with a factory installation. I eventually found the right truck with everything I wanted already installed.
No way in hell I would let the car dealer install that stuff. For 1 they will charge too much. Second, not sure they know what they are doing.In the market for a Ford 250 or 350. If the dealer wants to add the 5th wheel prep as an aftermarket item. Is that as good as the factory 5th wheel prep?
