There is a weight factor that must be taken into consideration. If your hitch is rated at 5000 lbs then your towed including contents should not exceed that limit plus, I'm pretty sure everywhere in North America, requires a towed vehicle to be equipped with a baking system.Well, thank you so much. I was wondering about total combined weight, and it seemed that w/o a trailer, it wouldn’t be an issue. Sounds like the way to go…
And not all Jeeps are flat towable.I will also mention, not all vehicles are flat towable. Jeep being the flat tow choice of many.
I know right!!?? I guess I am just a Jeep purist having owned three REAL Jeeps and one wannabee. It irritates the heck out of me to see the nameplate being used on a 2wd "car" .And not all Jeeps are flat towable.
My sweet 2011 Jeep Grand Cherokee Overland w/Quadratrak II 4WD ( 62k miles), which my evil 16 year old granddaughter has now carjacked ( but she nevertheless has excellent taste), is flat towable. The GC w/o QT II is not.And not all Jeeps are flat towable.
But, certainly not the cheapest. Baseplate for the toad, towbar assembly, braking system (Brake Buddy, Air Force One, etc), battery kill devices and assorted wiring, and of course labor to install everything if your not able to by yourself will cost you $5K to more like $10K, plus.The only real wear and tear would be tires. I have never had any other issues. In fact flat towing a vehicle is the easiest process of all
LMBO I have no idea where folks get quotes for setting up 4 wheel flat towing. 10K plus?But, certainly not the cheapest. Baseplate for the toad, towbar assembly, braking system (Brake Buddy, Air Force One, etc), battery kill devices and assorted wiring, and of course labor to install everything if your not able to by yourself will cost you $5K to more like $10K, plus.
I tow my wife's Kia Sportage on a Master Tow Dolly with surge disc brakes Dolly bought new in 2023, $2300. Nothing else needed. Car follows path of the RV, can't back up with it just like a flat tow setup, dolly by itself weights 500# and is easy to hook and unhook to move around, and is probably as easy and fast to hookup, load car, etc tie down tire straps, than hooking up a flat tow car. And, better braking on the dolly with the surge disc brakes than expensive $$$$ braking adapters used when flat towing.
I tow with a dolly, but it's not even close to being as easy or as fast to set-up as flat towing. That's magical thinking. I'm just not a fan of monkeying around with flat tow braking and battery issues. I have the Blue Ox flat tow equipment, but the pita factor hasn't incentivized me to the point of adding base plates and buying a brake buddy, yet.But, certainly not the cheapest. Baseplate for the toad, towbar assembly, braking system (Brake Buddy, Air Force One, etc), battery kill devices and assorted wiring, and of course labor to install everything if your not able to by yourself will cost you $5K to more like $10K, plus.
