redbaron
Moderator
- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Since taking ownership of my 2022 London Aire, I have been plagued by random failures of the TPMS. I have read the many reports online regarding this, and I followed the procedures everyone had posted.
I had 5 separate trips to NIRVC to have the TPMS worked on, and each time a random failure would continue to occur.
The first attempt at fixing the problem was installing a 2nd antenna. The subsequent attempts where moving the antenna around, pointing to various areas of the coach. On 10/4/2022 NIRVC made the call that it is pointless to keep trying, and referred me to Spartan.
Going into this, I knew this would be the outcome, but I had to keep pressing the issue until NIRVC had made every attempt to repair. In my opinion, they put more effort into this than required.
Armed with the data to support the equipment failure, I contacted Spartan Customer service and spoke with Dave. He took my information and put it into an escalation file of those owners that have had the repair attempts. He indicated that he is well aware of the issue, and there is no plan to repair the problem...but they are "working on it"....which is code for "go away, we don't want to deal with you".
That call was logged in my journal, and then I called my Newmar window rep. As expected, the call was routed to the main line (why even have a special number if you never answer it?) and a normal customer service rep answered.
I know this will shock many of you--but after he delivered the company line "I have never heard of this before"...he actually did say "Well, I have heard of it many times, but I thought there was a fix".
The result, is another documented call with Newmar for this problem in my journal as well as in the journal of Newmar.
After calling Newmar, I contacted Spartan Lync corp support, and left a voicemail. I then contacted the USA RV Support Specialist in Michigan:
Derek Stewart Phone: 734-634-3278
Email: dstewart@spartanlync.com
RV Customer Support
I left him a voicemail as well.
After following the above procedure, I proceeded to open a case with the NHTSA. For those that have followed my posts, you will remember that in 2019 I did a similar campaign for the Freightliner dash lights that resulted in a recall after 18 months.
I would like to solicit the RV Forums community to come together to get a solution to this problem. The more complaints we can solicit in a quick manner will escalate this with the NHTSA.
Some general guidelines:
#1 -- USE YOUR OWN WORDS -- Do not copy / paste text from others. This will be quickly dismissed as a robot or spam, and may put the entire campaign in jeopardy.
#2 - Be clear on your repair efforts and symptoms. My symptoms are random, so I stated that. My symptoms only occur while driving, so I stated that. Whatever your symptoms are, be sure to be as clear as possible.
#3 - Contact Spartan Chassis @ 800-543-4277 x1 and provide your vin number and get on the list for escalations **BEFORE** you create the NHTSA report. This way you can include details of your conversations with repair and Spartan in your report
#4 - Contact SpartanLync at the number provided above to lodge a complaint. This will put pressure on the supplier
#5 - Contact Newmar customer service and lodge a complaint. This step will again put pressure on the supplier.
To file the NHTSA complaint, go to this url:
Report a Safety Problem | NHTSA
After you input your vin #, it will ask you to select the failed component.
Select Wheels as this includes Sensors.
The rest of the form should be completed in your own words with your own information. We know the NHTSA does not move fast, so the concentrated effort on the entire supply chain will help put this through. I have experience with this, both in the RV industry and other industries--I guarantee you that this will work if we all register our complaints.
I am posting this here in the Newmar forum, but this applies to anyone with a Freightliner or Spartan Chassis and Gen 1 TPMS sensors from SpartanLync. Please share with your friends and others that may not be on this forum.
RV Customer Support
