TPMS Max and Min pressures
Our EezTire TPMS manual suggests the high pressure alarm parameter be set 20% above the normal cold tire pressure and the low-pressure alarm parameter be set at 10% below normal cold tire pressure. I think that is pretty standard.
I’m surprised that the manual for whatever TPMS unit you are using doesn’t give you the high/low alarm parameters.
Thank you very much. The manual is seriously lacking, but everything appears to be working.
I guess the question that pops into my mind is “Are you willing to trust your safety to it?” If the “manual is seriously lacking,” is the actual product any better? A TPMS is a pretty critical part of RV safety in my estimation and I want a solid, reliable unit watching my tire pressure and temperature. Yes; a good TPMS is more expensive than some of the Chinese-made knock-offs out there, but what is your safety worth?
