Trump Administration Announces Latest Action to Address Diesel Exhaust Fluid (DEF) System Complaints
Jim
North Carolina
Essex 4543
Spartan
Cummins / I6 Diesel Pusher 605HP
2016 Jeep Rubicon
I suspect this will have even less effect on what auto manufacturers do than the relaxation of fuel economy requirements did.
It's a change authorizing a software change only which will enable normal to near normal operation for up to 4 wks after a DEF system failure in non farm vehicles and up to 36 hours in farm equipment.
Which will go a long way towards solving the problems farmers are facing today.
The questions I have are, will we be notified by our diesel vehicle suppliers when a software change is available, and how much will they charge to do the reprogramming?
The present situation is untenable for RVers, let alone truckers and farmers. Imagine you are on a thousand-mile trip home, and you get the dreaded 150 miles to limp mode message. That will ruin your day.
The press release actually says two things which can't both be true, it implies the DEF sensors can be removed but then says emissions standards will remain the same. If the DEF system is disabled, for whatever reason, the vehicle can't be in compliance with emission's standards.
They are changing the sensor to a more reliable one...............The new EPA policy allows manufacturers to replace traditional urea quality sensors with nitrogen oxide (NOx) sensors, which the agency considers less prone to failure. The policy also confirms that software updates enabling these changes will not be treated as illegal tampering under the Clean Air Act........The EPA emphasized that emissions standards remain unchanged. Instead, the agency is shifting how compliance is achieved, focusing on reliability and real-world functionality.
Manufacturers are now encouraged to develop and deploy software updates for both new and existing diesel equipment. The EPA also signaled the possibility of additional rulemaking ahead, including a proposal to eliminate DEF-related derates entirely in future vehicles.
Further analysis is expected once all manufacturer data submissions are complete.
Just wondering - if the Nox sensors are "less" likely to fail, but if one does, is the def simulator still an option?
A DEF simulator will have no impact on the actual emission detection at the tailpipe. There is no reason to have any DEF system oversight at all, since the emissions, not the DEF system, are the object of control.
