Russellvh
- Nov 18, 2021
- Home based out of the Colony, Texas
- Forest River
- Wildcat Fifth-wheel
- 2019 Ford F-250.
- Yes
Thanks, I measured the height when I first got the RV. Highest point of the highest AC is 13’7”. I use 14’ as a limit to be safe.@Rich W. by spec from Newmar I think you're 12'10 - curious what you actually measure up as.
To all though, not knowing you're actual height and using a value too tall is just going to be cause for needless routing where shorter routes may be available. Know your numbers...I use actual plus 6 inches.
Im just going by memory which isnt very reliable. I’ll measure again and record it clearly to eliminate guess work. Also the 890 has done a nice job of routing me around low clearances so far. I wont solely rely on it but its a nice feature.@Rich W. by spec from Newmar I think you're 12'10 - curious what you actually measure up as.
Well I finally got off my butt and onto a ladder and my height is 12’9” (153”) on High and 12’7” on low So my recollection wasn’t far off, and when I measured it last time I didn’t have help. This time I made it a 2 person job and my measurements are precise. I agree with the ”plus 6” rule - I like a safety margin too. I used a 12’ step ladder and a door level (78”) to measure from the top of both ACs. Interestingly both front and rear were the same height - how nice!@Rich W. by spec from Newmar I think you're 12'10 - curious what you actually measure up as.
Could be an Active Air thing. I’m visiting HWH on the Monday following my week in Nappanee for a check-up as I’ve had some leveling issues, so I’ll ask them, but an inch plus or minus from the listed spec (Newmar’s guestimate) is probably not too unusual. Or for me either - I’m at least an inch shorter than my previous spec tooSounds like you're sagging a little. Not uncommon for anything with age..ehemmm![]()
