VIN 15 - Factory Build Log
Post # 6
VIN 15 Build Path Tracker | April 8, 2026
✓ Station 0 – Parts Staging
✓ Station 1 – Underbody
□ Station 2 – Tub Frame and Actuator Calibration (walkthrough completed 03/25)
□ Station 3 – Interior Assembly (walkthrough completed this week)
>> Station 4 – Canopy
□ Station 5 – Marriage
□ Station 6 – Validation & Testing
□ Station 7 – Delivery
Legend:
✓ = VIN 15 current progress | >> = current post documentation | □ = Upcoming stations/posts/videos
Quick summary
VIN 15 is colloquially at Station 1.5, moving to Station 2, while canopy assemblies continue separately at Station 4. This week’s walkthrough of Station 4 covered:
  • Canopy structure and lift architecture
  • Bonded solar roof installation
  • Centralized wiring and service access strategy
As with earlier stations, the canopy reinforces how Lightship’s construction differs from conventional RV methods: components are integrated rather than attached, bonded rather than fastened, and routed through centralized service paths.
What happened this week
VIN 15 advanced meaningfully within Station 1 this week through installation of:
  • HV charging architecture
  • Battery management hardware
  • Coolant loop completion and test
  • Fresh and wastewater tanks
  • Dump valve actuators
  • Front axle wheel installation
Remaining step to finalize Station 1 is installation of rear drive unit and CV axles.
Station 4 – Canopy
Hayley and Keegan walked us through Station 4 this week.
Exterior Design Approach
Lightship wasn’t designed as a box with features added later. The aerodynamic shape came first, and everything else followed. The canopy, glass wrap, and solar integration aren’t styling choices, they’re structural outcomes of designing for efficiency under tow and energy independence at camp. It’s a built-not-bolted approach, resulting in a trailer designed from first principles for the electric era rather than adapted from legacy RV assumptions.
Integrated Solar Roof
The roof carries 11 bonded panels totaling roughly 1.7 kWh. Panels sit flush within recessed geometry and are installed using perimeter bonding methods similar to automotive windshield installation. Wiring is routed internally as panels are placed.
Structural Hoops and Lift Loads
Four structural hoop members distribute actuator loads across the canopy shell. Rather than concentrating forces locally, these members transfer lift loads across the frame during raising and lowering cycles. They are also some of the only canopy areas not occupied by windows.
Umbilical Electrical Architecture
All canopy electrical systems route through a single connection point referred to as the umbilical. This carries: solar power, lighting circuits, fan systems, signal wiring and controller interfaces. Centralizing this connection simplifies routing and improves service access compared with distributed harness penetrations.
Magnetic Interior Service Panels
Interior headliner panels attach magnetically rather than mechanically, allowing access to wiring and lighting systems without removing bonded components.
Seal Architecture
A dual-stage sealing interface engages when the canopy closes, reducing HVAC losses while providing environmental protection. The seal system also compensates for small dimensional variation between canopy assemblies.
Bonus preview – Canopy 2.0
We also saw early elements of the next canopy revision, including:
  • aluminum structural frame sections
  • increased in-house manufacturing control
  • improved dimensional consistency
  • expected stiffness and weight improvements
This version will likely justify a separate walkthrough later in the series.
Photos and Video
This week’s walkthrough video focuses on canopy structure, integrated solar installation, wiring architecture, and a brief preview of Canopy 2.0.
Next Station in the VIN 15 Build Sequence
Station 5 – Marriage, where canopy and tub structures are joined into a single assembly before validation and systems testing begin.
