Yes. With battery switch off and anti reverse fuse pulled charger indicates 27 volts. No load condition. This is test progressive dynamics tech had ne perform before warranty replacement.
Yes. With battery switch off and anti reverse fuse pulled charger indicates 27 volts. No load condition. This is test progressive dynamics tech had ne perform before warranty replacement..
Btw.. curiously the replacement board serial number is identical except for last number which is only 4 digits higher…
Bad batch?
This is a 12 volt converter only. Lithium switch on board boosts output to a nominal 14.6 volts per manual
exactly!Switch turned off and fuse pulled - in my mind that doesn’t ensure the battery is disconnected. I would physically detach the cables from the battery bank and then test the battery - this ensures that NOTHING is back feeding voltage to the battery.
