WATER LEAK outside of shower when gray tank full?
VMMouse
I purchased a used 2019 Minnie Drop 170S. Apparently gray tank was full as some water (not full) was in shower basin. Puddle on floor in corner to right of shower and continued until I emptied the tank. Is there some sort of overflow there? THANKS!
That is how they typically overflow. Definitely want to monitor tank levels and avoid ever going beyond 90%.
The water was outside the shower? It should be in the shower basin. Check for a leak under the shower. Perhaps the drain pipe is loose at a fitting.
yes; but the question is how to access as don't see any access panel at the shower
Is there a furnace vent undernthe shower? That may be the access point.
It may be worth cutting out and framing an access door. Of coursbone would need to know that nothing is on the other side first. I am considering doing this with mine.
