Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
thats as deep as it gets.Two each? Wow that is heavy math.
Sign. It's always something. My black tank sensor is showing 100% full although empty. It tends to do that on travel days and will usually go down as the gray tank goes up. Not usually a problem except lately since I've been staying at Harvest Hosts where I don't have access to city water, so I can't just take the fuse out and flush away. Today I'm at a KOA in Des Moines, IA and NOTE TO SELF => carry an EXTRA WATER PRESSURE REGULATOR. Lately, I've been staying at places with lower water pressure so I tightened my Watts Adjustable Regulator way down. Well now I'm at a CG that is blasting 80 psi and I can't loosen it to let up the flow. So now I have access to city water, but too powerful and I have the happy red light indicating that my empty black tank is full and yeah I'm just risking it. I pray I don't blow out my pipes.
So, I'll be buying a second adjustable regulator. I do carry extra fuel filters and belts, but today's little problem got me thinking...what ELSE should I be carrying TWO of? What extras do ya'll carry in your rig?
To each their own. I want MY pressure regulator at the tap and before the hose. I know...I know...the hose is supposed to be rated at something like 150 PSI, but it is still a weak link in my mind. I'll stick with regulating the water pressure outside of the coach.
To prevent that from happening if a connection should come loose, I have installed short lanyards with clips on the free ends that attach to small screw eyes I installed on the coach and towed.I learned this weekend that it’s useful if you have an Air Force One braking system, to carry a spare air hose. I did not check my air connections well enough and the connection to the tow vehicle came loose. I realized it within less than a mile but it was too late. The female quick coupler had been severely damaged and could no longer be connected to the truck. We had to drive the truck and RV separately, for a 5 hour trip
The air hose itself was fine and I checked Autozone, O’Reilly and NAPA Autoparts for a replacement 3/8” female coupler with 1/4” FNPT threads and came up empty handed. Everyone only had 1/4” couplers.
No one carries the couplers or air hose. We had to drive the truck and RV separately, for a 5 hour trip. If I traveled solo, I would have been SOL.
I ordered 2x replacement female couplers, 1x replacement male coupler and a replacement air hose from etrailer.com that way if I ever drag the air hose again, we’ll be able to rectify the situation quickly.
I also forgot to mention I also carry a spare surge module for my Huges Autoformer 50amp Power Watchdog.
it’s always the thing you don’t have that fails or you break. I know none of these things I carry will ever be needed, since I have them now.
Well done. Wish I were that smart but I’ll get there one day. That should be in the dirt cheap easy mods thread.To prevent that from happening if a connection should come loose, I have installed short lanyards with clips on the free end that attach to small eyes I installed on the coach and towed.
Not if you want include the cost of repairing the damage to your wetbay cause by a blown hose. You probably won’t notice a failure immediately until you see water draining from your wetbay door at which point you can only hope that it’s all contained to the the little 1.5” tray and hasn’t been hosing down your entire bay for the last 4 hours.The 2nd regulator is more expensive than a replacement hose.
That’s hilarious and I WANT to see the video!Oh goodness, this is so simple. Put your mouth around the city water spigot and turn the water on full. If it puffs both cheeks out that's 80psi. Turn down until only one cheek puffs out, that's 40psi. Best if verified on video, posted for verification.
