What is this valve fitting and why would it come out?
TXfreeze
RVF VIP
Holiday Rambler
Endeavor
Roadmaster
350 Cummins
None
Yes
The other day with no warning, water started leaking from under the sink at an alarming rate, I determined the culprit was a valve fittng , please see the attached photo. I put it back thinking it might just be for city water not tank, tried it with pump, popped right out, so I wrapped it with some duct tape and it staying in place but only with limited use of the pump, we really would like to get back on city water since we aren't boondocking, but I'm certain as soon as I try to use city water the pressure will be too high and water will find some way to get out, do I need to replace it? I left it in the up and down orientation if that's right, couldn't I just rubber cement it in? Thanks for any help.
Are you saying the gray pipe is slipping out of that white plastic knurled nut on the T fitting?
If so, that knurled part is actually a nut, and there should be a compression ring of some type inside.
It might be that the compression ring is cracked and no longer able to keep the pipe retained.
I suggest closer inspection is called for, and parts replacement as needed.
Re-reading your post, it now sounds like you're describing that the turn handle is popping out of the valve body. If that's the case, then you'll have to get a new one. Local Camping World should be able to fix you up.
BTW.....that valve is a water direction control valve. I don't know exactly where those gray pipes go, but I will guess that it directs water from city supply to tank or to camper system, whichever is desired.
Roger
Yes it's the turn handle, so it's obviously warn and needs to be replaced I guess, thanks
Is this what i need to replace it with? RecPro RV Plumbing Hardware | 06910 | 3-Way 1/2" Compression Fitting Directional/Bypass Valve | Pex Pipe/Tubing Fittings (1 Fitting) Amazon.com
If this was damaged while on city water, your pressure may need regulated down. Some water hookups have pressure over 80 pounds. My internal pump is 40 to 55 pounds. I have s tiny drip in my plumbing when pressures are over 80 pounds at some campgrounds.
Your piping appears to be polybutylene pipe; polybutylene pipe is thinner than pex. Polybutyelene also does not hold up to bleach. If you use bleach to sterilize, be sure to rinse the bleach out. Bleach will harden polyeutylene pipe and then it will shatter or crack.
It certainly looks the part, but there could be two different configurations in that same valve. It could direct water to one OR the other outlets, or it could direct water to one or both outlets. You'll need to check what your old valve does before ordering.
Roger
Limited-time deal: RVGUARD RV Water Pressure Regulator Valve, Brass Lead-Free Adjustable Water Pressure Reducer with Gauge and Inlet Screen Filter for RV Camper Travel Trailer Amazon.com
Try this if you do not have one.
Drain the system. Mark the valve so you know how to put it back in. Loosen the couplers on the three sides. Hopefully you have enough room to slide back the piping and remove the valve. Look inside the valve and you can see which way the water will be directed when you move the valve. I suspect it is a “diverter valve” to change from shore water to tank water. If you have two fresh water tanks, the valve may switch or combine tanks.
I do have 2 fresh water pumps, so you think it's a diverter valve?
Thanks I don't have one, do I need the adjustable one?
I "think" is is a diverter valve. Have you removed the valve to check to see what the handle actually does to the water flow inside?
Yes I would get the adjustable pressure regulator. I had the regulator with the gauge and left the regulator at a campground.
