Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I welcome anyone and everyone to add to this list of what you carry in your RV toolbox. I may come back and edit and link up the actuals I own and where I got them. But for now and for starters I'll start listing things out as I recently reorganized my tools so it's sort of fresh in my mind:
- Screw drivers from compact versions to larger ones as sometimes you have to get into tight places inside the coach
- Pliers, vice grips, channel locks (more for getting sewer covers off at the CG), a few clamps should I need to glue something back together
- Dewalt powered screwdriver (I have the gyro one), Dewalt drill, Dewalt impact driver, all cordless
- Caulk gun
- Dicor, Silicone, Sikaflex 221, Sikaflex 252, Skylight sealant (from when I had to replace one from hail damage)
- Crescent adjustable wrench(es)
- Wire cutters
- Larger cutters I later added to remove pex clamps
- Needle nose
- Long needle nose when I had to remove the cotter pin from the Kwikee steps
- Voltmeter
- Clampmeter
- Voltage detection pen (hold near 120V or 12V to determine if there's power)
- Wire tracing device
- Hammer
- Hatchet
- Pole Saw
- Stick Ladder (stored above chassis rail) (okay, it's not in the toolbox, but for some reason I wanted to list it)
- Various screws, wire nuts, wire crimps, butt connectors, spade connectors
- Wire stripper
- Wire crimper
- Pex crimp tool
- Assorted hose clamps
- Various glues (JB weld, epoxy, etc.)
- Electrical tape
- Rescue tape
- Pipe sealant tape
- Various lubes (silicone spray, wd-40)
- Brake cleaner spray
- T-9 lube
- Hose pinch off pliers (2) in the event I have to replace an OASIS pump
- Toolkit that has the assorted wrenches, knife, sockets, T bits
- Assorted pieces box like a plano tackle box with various screws and things collected over time
- Oil filter wrench for onan service
