- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
In another thread we are discussing the value of NIRVC's Rettrobands which lends to when will a RVer replace your tires? This is not limited to Class A Motorhome discussion as that's what I drive, this is for every RVer. When are you going to replace your tires? Any of the tires?
A rule of thumb I've heard for Class A's is around 7 years on the front "steer" tires. The next question is this from the DOT stamp on the tire or the actual time it started rotating on your coach? What am I going to do? I'm still undecided. I take great precaution with my tires from tire pressure being on the plus side of the charts by 10 or so PSI. I use a tire pressure monitor. I keep them covered (which I think is more on the gimmick side as sun damage would take years I believe and combined with non use). I will evaluate at 7 years and probably change them, this will be 7 years from the earliest DOT date on my steer tires, replacing in pairs.
My rear axles I will consider at the 10 year point. Again, I'll also combine this with a visual inspection and a touch of emotion. I have a lot of faith in Michelin so that weighs in as well.
What is your intention with tire replacement and again this is for all RVers. I'm curious if trailers have the same concerns as Class A owners. How about Class C?
