NopeI've got a 7,000 lb tow behind camper. I'm looking to buy a V8 half ton or 3/4 ton pickup to tow it. Wondering if the half ton is enough to get it up Colorado mountain passes easily?
I wouldn't buy a modern diesel for the occasional trip towing, say ~7000-9000 lbs. Only if someone were towing frequently or towing over 12k lbs.I've towed all the major passes in Colorado. A v8 gasser like a Ford 7.3L will do it but with a couple down falls. It will be way up in the RPMs to make the power needed. It will empty your wallet in fuel consumption. And the biggest for me is the lack of an exhaust brake coming down the back side.
Get a diesel and you will enjoy it much better. Love mine in the hig hills towing 12k.
Dropping down Wolf Creek or Monarch or vail without touching the brakes once is a real nice feeling.
I would go 3/4 ton. There's no modern half ton I can recommend from a reliability standpoint. They're not really built for that kind of work any more.I've got a 7,000 lb tow behind camper. I'm looking to buy a V8 half ton or 3/4 ton pickup to tow it. Wondering if the half ton is enough to get it up Colorado mountain passes easily?
How fast do you normally go around hairpin turns in a ~15k pound GCW rig?One problem with a half ton is that you will probably be using a weight distribution hitch with this combo. WD hitches are dangerous going around hairpin turns, so you have to slow way down to keep your rig from jackknifing. You won't need the WD hitch with a 3/4 ton truck.
