Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I keep trying!If you plan on boondocking or even staying in truckstops or Walmarts overnight and you can afford a solar system with Li batteries, I would say yes. I cannot sleep through the night without worrying about how far my batteriesbwill be down in the morning, unless I run the generator all noght long (slow money bleed method). The problem is when the truckstop is full and rv’s are packed mirror to mirror, I could be down more than 50% by morning and damaging the batteries.
so, if I were in a position to do solar and Li, I would.
The reason I preach again that is!I’ve been struggling with the idea of installing Solar on the New RV. My last RV had lots of solar and LiFePo batteries. When we were traveling and didn’t need AC it was great. The downside is we never used the generator and when we needed the genset it wasn’t happy.
That experience got me powering up the generator every month to exercise it.
So, why don’t I just have a large battery and use the generator to keep it topped off?
That is where we are now, large battery and are going to use the generator and see how it goes.
I have an LP generator. It cranks right up after long periods of non-use, even years of non-use. That is why I opted to install an LP generator. It also sucks up a 20# LP tank every 8 to 9 hours running at a 50% load (it always runs at 50% or less because that is how I sized it). You can add an LP fuel conversion kit to many gas/diesel generators and it works just fine.I’ve been struggling with the idea of installing Solar on the New RV. My last RV had lots of solar and LiFePo batteries. When we were traveling and didn’t need AC it was great. The downside is we never used the generator and when we needed the genset it wasn’t happy.
Is solar worthwhile? I certainly this it is. I put 1800 watts of solar on the roof and replaced the 400ah (200ah usable) FLA batteries with 600ah of Li and don't regret it for a second! At first I thought we'd need to change the way we use our electric, to be more conservative, but soon discovered the batteries were back to 100% by noon the next day. The only other significant change was to toss the incandescent lights and go 100% LED. Our longest off-grid camping was 15 days near Quartzsite before needing to empty holding tanks.
Is your fridge a compressor fridge?How much does your battery tend to drain overnight? Do you have a fridge that runs on 12V?
I’m trying to figure out if ours are running normally.
Yes your system is running normally!!! Of course your normal may not be everyone's normal.How much does your battery tend to drain overnight? Do you have a fridge that runs on 12V?
I reference stuff like that to help illustrate efficiency as well as help people think!!! Think in terms of parables! A story is like a picture!!! It captures the imagination.This discussion is between people talking about PV energy and generators. I don't see how making hot water helps top off any type of battery. Other then not needing electrical energy to produce it(hot water). Still has the storage and transporting it around gracefully issue.....so where did you want this discussion to go Kevin? No one is going to bolt a box filled with pex and covered with an old window to the top of their class A. And run the lines down thru the roof also? Well, most won't....
I considered doing this years ago at my sticks and bricks in Maine. I instead watched what others had done and experienced in my particular climate/area and stayed conventional. Much like wood heat, there is no free lunch. The amount of labor(yours) in wood heat in a cold climate is usually underestimated by novices. Storage, quality(type of wood and dryness), access to heated areas and ash dumping along with chimney fires/appliances to burn it make wood heat less then ideal for many people. But I digress....lol
Spent to many years as a nomad to understand what you mean by that! Your knowledge on oasis makes me wonder what you mean by the other!Hmmm, most are not set up semi permanently in one spot. And floor heat is another area I know enough about to be dangerous. As with other things, it depends.
