Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I keep trying!If you plan on boondocking or even staying in truckstops or Walmarts overnight and you can afford a solar system with Li batteries, I would say yes. I cannot sleep through the night without worrying about how far my batteriesbwill be down in the morning, unless I run the generator all noght long (slow money bleed method). The problem is when the truckstop is full and rv’s are packed mirror to mirror, I could be down more than 50% by morning and damaging the batteries.
so, if I were in a position to do solar and Li, I would.
The reason I preach again that is!I’ve been struggling with the idea of installing Solar on the New RV. My last RV had lots of solar and LiFePo batteries. When we were traveling and didn’t need AC it was great. The downside is we never used the generator and when we needed the genset it wasn’t happy.
That experience got me powering up the generator every month to exercise it.
So, why don’t I just have a large battery and use the generator to keep it topped off?
That is where we are now, large battery and are going to use the generator and see how it goes.
I have an LP generator. It cranks right up after long periods of non-use, even years of non-use. That is why I opted to install an LP generator. It also sucks up a 20# LP tank every 8 to 9 hours running at a 50% load (it always runs at 50% or less because that is how I sized it). You can add an LP fuel conversion kit to many gas/diesel generators and it works just fine.I’ve been struggling with the idea of installing Solar on the New RV. My last RV had lots of solar and LiFePo batteries. When we were traveling and didn’t need AC it was great. The downside is we never used the generator and when we needed the genset it wasn’t happy.
Is solar worthwhile? I certainly this it is. I put 1800 watts of solar on the roof and replaced the 400ah (200ah usable) FLA batteries with 600ah of Li and don't regret it for a second! At first I thought we'd need to change the way we use our electric, to be more conservative, but soon discovered the batteries were back to 100% by noon the next day. The only other significant change was to toss the incandescent lights and go 100% LED. Our longest off-grid camping was 15 days near Quartzsite before needing to empty holding tanks.
