Scotttkd2
- Jun 1, 2021
- Fort Myers, FL
- King Aire 4561
- Spartan K3
- Cummins ISX 650
- 2019 Jeep Cherokee
- Yes
Yup, not a good day 1 of most recent trip. Currently sitting in Albuquerque NM with RV at a Freightliner shop for the foreseeable future. Driver side steer wheel shredded and took out the electrical bay. No power steering, no dash, no slide controls, no levelers, cant start engine. Wound up partially in the median of I40 with patio side outside dually off the ground. Luckily we didn't roll it, and I had just swapped out the blue ox tow bar that bound up if not perfectly flat for the NSA ready brute that had enough rotational give in the attachment points to release the toad Even at the angle we came to rest at. Recovery tow dude was a miracle worker and managed to get hooked up and drove it into the bottom of the median without rolling rv and himself and was able to get it out. Once Freightliner finishes its repairs it will need to go to a body shop for their work, so we are grounded for a while. Luckily no injuries and didn't cause any accidents as it went from the right lane all the way to the median. TPMS was active, no warnings, and all tire readings were in specs and consistent across the board with the usual running temps and PSI. 19k miles on this one, the front right tire looks perfectly normal and healthy. Scratching my head on why this one would have blown, rear blowouts a year ago were related to Freightliner valve stem recall and I can understand why they went.
