i got to weigh the coach on axles onlyI would go to a CAT scale and weigh (make sure you have your axles on different scales. Then, for each axle, multiple by .53. So, if you came out at 9300lbs on the front axle, 9300 x .53 = 4,929 and use that as the weight for both tires on that axle. Do the same with the other axle, then look up the PSI in the Michelin load chart.
The .53 is recommended when you don't have a four corner weight, as typically one side is heavier than the other, so it's about the best option you have short of a four corner weight.
So since you don’t have four corner weights, using the total axle weight x .53 (thank you Tnedator) you end up with 10,387 so I definitely run 100 in the rears until you have weights for both side. Even if you divide by two and multiply by 1.03, you’re still at 10,093 which puts you in the 100psi column. Also with four corner weights you’ll probably find you can run 110 in the fronts.Front 11464
Rear 19599
What is the weight limit on the front axle per the tag just behind the driver's seat, left wall? Take a picture and post it if you want.Mkern......My Kountry Star appears to be a lot heavier in the front (13600 on the Cat scale) and uses the same 275/70r22.5 size tires, I have to run them near max 130psi cold to cover that weight. I am concerned that is not the best idea to have engineered a design that relies on running a tire at the very top of its load range. Am looking at the possibility of fitting the 295/70r22.5 for the added margin, but no idea yet on clearance. Glad you got it sorted out!
having a tag helps….a lot!I think being cognizant of axle limits and getting corner weights is critical. We should not need to be running at sidewall max pressures. I'm running well above my chart mins which I think are 90 front and 75 rears. I run 105 front and 90 rears.
I’d also be concerned about an under rated front axle. Wouldn’t be the first time Newmar did that. Do you have the build sheet with factory four corner weights? That would be telling.I had to dig, but found a pic on my phone, 13500 front, 24000 rear with 130 front and 120 psi rear recommended on both FL label and Newmar label. Actual cat scale said 13660 front and 21800 rear. I have since offloaded a lot of weight we found we didn't need but at that time we were just starting full time so didn't know what we were or were not going to miss. I need to get it back on a scale once it's on the road again and see what our current load out looks like. Still think Newmar should have spec'ed a heavier tire for the front based on the tire chart recommendations though, I have my fingers crossed I have the clearance for the additional 2 inches in diameter, I would feel a lot better being able to run the fronts at less than max PSI rating given what has happened recently.
