i got to weigh the coach on axles onlyI would go to a CAT scale and weigh (make sure you have your axles on different scales. Then, for each axle, multiple by .53. So, if you came out at 9300lbs on the front axle, 9300 x .53 = 4,929 and use that as the weight for both tires on that axle. Do the same with the other axle, then look up the PSI in the Michelin load chart.
The .53 is recommended when you don't have a four corner weight, as typically one side is heavier than the other, so it's about the best option you have short of a four corner weight.
So since you don’t have four corner weights, using the total axle weight x .53 (thank you Tnedator) you end up with 10,387 so I definitely run 100 in the rears until you have weights for both side. Even if you divide by two and multiply by 1.03, you’re still at 10,093 which puts you in the 100psi column. Also with four corner weights you’ll probably find you can run 110 in the fronts.Front 11464
Rear 19599
