- Jan 19, 2021
- Rosemary Farm, Grass Valley Ca
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
Cross reference.Nice - was Blacktech OE or the result of research?
Progress! Also nice work-saver ideas. My little job today is mirror adjustment (shower valve was yesterday). Covid put travel plans on hold so I’m just doing a small project each day.So, Today is clean up the chrome stuff and put the wheels back on. You might know first hand that cleaning the nut covers is a tedious endeavor. So, came up with a rig that made it a 30 minutes affair. The end is a 3/4" drive to 1/2" drive adapter that happens to fit nicely in the inside of the nut covers. So it's very easy to spin the covers while applying a rag of polish on the end. You can see on one side those that are dirty, and those that are polished.
Cleaned the hub cap / bonnets using a standard foam polishing pad by putting the caps on a soft cloth and using my foot to keep it from skittering across the shop floor while polishing. One of my caps is beyond polishing....had to wire wheel off the rust and it's just a matter of time before it's covered in rust again, but good enough for now until I find an inexpensive source for caps.
Also, since my knee is not quite up to snuff (surgery in a few weeks), I had to come up with a way to mount the heavy wheels without overly stressing the bod. A few scrap 2x4s to the rescue. The width for my tires ended up being 16 1/2" inside measurement. The long lever boards are 24" long. You could make them 36" if you need more leverage. This made the wheel alignment and lift easy peasy.
So, used a 1/2" air impact to snug the wheels on.
Tires all back on and I realized I forgot to grease the underbody....so need to put some stand back underneath and be thorough...
