Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
Yes. Yours should have gen 3 Valor system. It works according to what I’ve read. Mine came with gen 1 Valor junk. It’s why I use a TST system.Silly question...doesn't Newmar Class A come with a TPMS monitor system??
My Baystar did not come with a TPMS, I use a TireMinder systemYes. Yours should have gen 3 Valor system. It works according to what I’ve read. Mine came with gen 1 Valor junk. It’s why I use a TST system.
Well, I finally found what I’d been searching for, which was a more encompassing Tire Monitoring System that turned out to be called the Trailer WatchDog system. It monitors individual tire pressures & temperatures, as well as individual hub temperatures.If I may ride the coat-tail of this thread my TT has just two wheels, yet I’ve not seen anything available for just monitoring two wheels. That said and thinking ‘if’ I’m on my way to a flat sometime, with only two wheels, it's critical I know ASAP. So for some of the more seasoned RV’s here with experience, what TPMS might you recommend? BTW, I’m in the quality before economy camp.
At this point, from what little I’ve read, I’m leaning toward an EEZTire-TPMS Pro (518C) Tire Pressure and Temperature Monitoring System.
Excellent point! Forgot about the tow.We were coming back from Florida towing our Jeep Cherokee when the Tire Minder alarm sounded, showing the pressure, think I had the alarm set at 28psi. By the time I could get over to a safe shoulder it was completely flat. They were fairly new tires and luckly was in time I had not damaged it. I had picked up a small piece of metal. Towing with the motorhome I think I would have ruined more than the tire had I kept going. That is why I look at them as a valuable piece of saftey equipment instead of a toy. JMHO
Over the years, I've had 3 flats on my tow. Each time I was saved by my TPMS except for when I first got my LA and was using chassis TPMS because I had not gotten around to installing my EEZ yet. Thank goodness for the good people of Arkansas who waved me down. I was lucky not to ruin the rim on that particular Good Friday. Had I gone a little further I would have been in a world of trouble.Excellent point! Forgot about the tow.
