JRS
RVF Expert
- Jan 25, 2020
- Full timers
- Dutch Star 4328 - FL Chassis
- 2018 Jeep Grand Cherokee
- Yes
Does the cost vary depending on need or is there a set list and price?We get ours done yearly at Gaffney regardless of mileage.
It's different every year as some fluids need changing and some not on each year's list. That, and adding other parts like air cleaner or belts affects the price. Gaffney has usually been the cheapest and best service. We just finished our 8th year there with this coach and have been very happy with their service.Does the cost vary depending on need or is there a set list and price?
Do you replace the belts every year? Or just if they show wear?It's different every year as some fluids need changing and some not on each year's list. That, and adding other parts like air cleaner or belts affects the price. Gaffney has usually been the cheapest and best service. We just finished our 8th year there with this coach and have been very happy with their service.
I have them checked by the tech and let him make the call. I carry a spare set anyway.Do you replace the belts every year? Or just if they show wear?
Do you have a list of what they inspect/maintenance? And what is everyone paying for this "annual maintenance"?I have them checked by the tech and let him make the call. I carry a spare set anyway.
That list should be in your coach manual. Here's the one from this service.Do you have a list of what they inspect/maintenance? And what is everyone paying for this "annual maintenance"?
I would reach out to FL and tell them your situation and they'll get you on schedule. Some items are time based replacements and some critical items in your coach may be expired. I'd get to them when you can and get them to get you sorted out. My guess for your coach it will be around 1500/year.So can we revisit this thread?
My coach hasn't been driven more than about 3K miles since the last Freightliner maintenance was done. But I've heard that there is a yearly maintenance that should be preformed, regardless of how many miles it was driven.
I have looked at the Freightliner Maintenance Schedule, and it is based on 6K, 15K, 30K, etc., but what is generally done on a "yearly" maintenance?
Or do I even need to worry about it since I drove so few miles?
Oh, another questions. What is the "usual" cost of an annual maintenance?
RV Factory Service Center
103 Campus Dr.
Gaffney, SC 29341
855-253-0421 *option 1
Jim, I may be somewhat out of bounds on this..... but I saw your notes about the IFS and omission on checking the hub oil? Like your's, I also have IFS but mine also has hub oil to lube the bearings (maybe your's doesn't?). My oil was actually changed last August.That list should be in your coach manual. Here's the one from this service.View attachment 21419
Sorry, just saw this. Our coach has a sealed bearing from what I've been told.Jim, I may be somewhat out of bounds on this..... but I saw your notes about the IFS and omission on checking the hub oil? Like your's, I also have IFS but mine also has hub oil to lube the bearings (maybe your's doesn't?). My oil was actually changed last August.
Seriously under 3k?Got the service today, asked on whether or not to do the oil change based on under 3K miles last year, they said yes, and I had no problems getting it done, I want it right. Great service as always at FCCC.
