FYI Starlink reveals new dish
Comes with V3 router as well 😎
Mounting is going to be interesting without the pole option.
I'm still holding out for a 12V RV friendly version, no router needed. Just want a PoE dishy.
I'll wait for the Q phone to upgrade, hear that they are the next big thing for starlink.
Speaking of Starlink, if you get the roof mounted Starlink dish referred to as in motion, the lowest cost monthly plan is 250, not 150 which is for the standard tripod or stationary satellite. The same terms apply.
I have the roof mounted Starlink In Motion and my Mobile Regional Plan costs me $150.00 per month for unlimited data.
Edit: I just received my email notification from Starlink for my next monthly billing cycle for my Mobile Regional Plan and it was, as it has been, $150.00.
Hoping that a new In-Motion Starlink dish comes out that uses standard CAT6 / POE cables.
Any rumors out there yet?
I don't mind (too much) of paying the premium for In-Motion dish. A one time investment.
If the new dish could be used floating on my boat in the inland lake, then maybe that's a good solution too.
Check this out...they convert it to 12v and put the router inside. Not what I'd want for my system with a stand-alone CradlePoint and multiple sources. But, this may fit the bill for quite a few of my contacts who want/need a simple solution.
I still think something for RVers is coming. Here is the latest update on the new dish:
It's interesting that that video calls it "disappointing" that the new dish is larger...and that it takes more power. I am sure the reason is that the new dish has more active receivers which should make the performance closer to the in-motion dish (which also doesn't have a need for tilt motors due to the larger array). The power increase is also due to the more elements (the in-motion has even more, and yes, consumes more power of the three).
Now, the real question is whether the new dish can be used in-motion...is this compatible with the motion data subscription?
At a minimum, the new dish should be easier to point, and get better performance with less than optimal view of the sky (partial tree coverage) due to the additional active receiving elements.
I for one thinks all the changes to the new dish are a positive. I like the thinner profile, the lack of need for motors (mechanical things that tend to fail and the extra depth that makes mounting more challenging on anything other than a pole mount). And certainly the additional surface area / active elements that make it higher performance (closer to the $2500 dish).
