Subwoofer Location - 2024 DS4369
GUS2000
South Louisiana
Dutch Star 4369
2017 Ford Explorer/2018 Ford SuperDuty
Anyone know where the subwoofer is mounted in the Dutch Star?? In the features and specs, the Newmar documentation indicates that the following is installed in the 2024 Dutch Star:
  • Dash Radio with Harman/JBL 180 Watt Sound System and Subwoofer
We had a similar system in our 2021 SuperStar and the subwoofer was great.. but in the DS, its either not working or not installed as we are getting no bass at all in the cockpit...
Mine is located behind a panel to the right of the entry steps.
Same here on 2020
thanks guys!! gonna pull that panel off and put on some good country music and see if its working..
Kazakhstan​
Found the sub.. no controls on it to make any adjustments in crossover or level.. it appears its connected to an amp.. any idea if the amp has any controls on it??
If it does, that fact is well hidden. As is the amp for that matter.
I control all sound levels thru the settings menu on the Xite unit.
I emailed Riverpark... asking for more information.. will let you know what I find out! even at max setting on the Xite interface, the sub is barely putting out anything..
It may be your music selection!!! Quality filters, do make a difference in what a speaker presents to the listeners from each speaker type.
Your best bet is find the make/model of the sub and go find the manual for it.
I had my dash radio setup, sub, and amp all redone (and speakers by myself) to significantly improve that situation. Moral is there may be an amp which is above the accelerator in my coach and you can check for a blown fuse on that.
If you can, try bluetoothing in music such as from Apple Music, Spotify, etc. and that's a better test of the subwoofer at least on mine. My dash radio SiriusXM doesn't do so well for the subwoofer testing.
Thanks, I have tried a few different "quality" sources of music and I will have to wait on the information from Riverpark since Newgle shows a different sub that should be in the DS...
For reference, I not only utilized the FM tuner, but baselined it off of the low frequency capabilities of the system we had in our 2021 Newmar SuperStar.. I also injected signal direct via apple car play as well as using the low level inputs on the core.
Kevin.. this one is for you.. since your "Quality" filter doesnt seem to be working this morning! 🤓 Now to the subject of music selection utilized for this testing/tuning.
ZZ Top - Tush
Eagles - Hotel California
Kansas - Carry On Wayward Son
ZZ Top - Tush
Don't know for sure but from what I can tell in the getto! Rap is the best for testing sub woofers!!!😉
Being a sound engineer and a member of the recording academy for 15 years, I have to disagree with that one lol
Not really my cup of tea! My radio gets tuned to mystery type channels. Even at that seldom turned on! Quite, and nature, is my thing!!! Bet you had a hard time figuring that out!
