JoeHogan
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
If teh System in teh 2024 DSDP is the same, When I was discussing the leveling routine with the TECH at CPU, if I remember correctly, he indicated that when you start the retraction of the jacks in the Accessory Key position that you let the cycle finish before moving key to Run/starting engine OR after start press Store again to get to ride height. Moving ignition switch from Acc to Run interrupts the Air up process.
My $0.02
My $0.02
