TheLooks
- Jun 30, 2021
- Harrison, TN
- Jayco
- 26 BH
- 29 ft
This discussion is between people talking about PV energy and generators. I don't see how making hot water helps top off any type of battery. Other then not needing electrical energy to produce it(hot water). Still has the storage and transporting it around gracefully issue.....so where did you want this discussion to go Kevin? No one is going to bolt a box filled with pex and covered with an old window to the top of their class A. And run the lines down thru the roof also? Well, most won't....
I considered doing this years ago at my sticks and bricks in Maine. I instead watched what others had done and experienced in my particular climate/area and stayed conventional. Much like wood heat, there is no free lunch. The amount of labor(yours) in wood heat in a cold climate is usually underestimated by novices. Storage, quality(type of wood and dryness), access to heated areas and ash dumping along with chimney fires/appliances to burn it make wood heat less then ideal for many people. But I digress....lol
