Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I get it! Kind of like putting 500 watts of solar on the roof, and expecting to heat or cool your RV! It can help but to do the job right it requires more engineering!Radiant heat is much more difficult then just heating water and circulating it. Transfer rates, temps, and other factors make it tricky.
Point is it is just a matter of knowing the limitations, and adjusting your expectations. We aren't planning a product, just wanting to increase comfort!!!
As an example, installing 1.5 Sq. Meters of collector would be less than using a space heater for the same 5 hours of useful heat collection. It would help, but hardly do the job! Then there is the temperature difference of the heat exchanger(solar collector), that determines the actual energy collected.
But there are other advantages to covering your roof! Yes shade! That is a summer time advantage, that could help keep temperatures lower in the summer.
Thank you for stretching this conversation to a subject matter that, those that can't visualize electron flow, can follow! No matter how far off topic this seems to have strayed, one can see the physics is similar to the original topic!!!
