JeffAndPam
- Jun 26, 2023
- Alabama
- Fleetwood
- Flair, 34R
- 34'
I like @Underboss suggestion and might consider adding a little fiberglass embedded in the epoxy for strengthOne of our fenders completely ripped off. Would like to know a relatively easy approach to get this back on.
It's a 2005, so it doesn't need to be a polished solution.
That was good advice! Trying to line the broken pieces up after taking them off would be problematic.I think I would try to superglue it back on to the tabs. Just to make sure they are in the correct position. Then remove it all and work on it from the backside.
For some reason I can get the link to paste. But I have had a lot of luck with this product.One of our fenders completely ripped off. Would like to know a relatively easy approach to get this back on.
WELL said!it was quite a project.
Me too! Previous owner briefly told us it came off and they stuck it in one of the bins.Still waiting to hear how it happened in the first place?![]()
Very good details. Thanks for the thorough response.Use "DuraGlass" and "glue" the FRP to the backside of the fender
Take a picture of the damageVery good details. Thanks for the thorough response.
Your mention of "DuraGlass" (had to look it up) makes me want to add another question to this:
I have a hole on the side of the RV that needs patching. (I have so many questions about this RV, I'm having to trickle them on here). It's about 3" by over a foot in size.
So when I go to tackle that project, I'll need to purchase some product. Would "DuraGlass" be useful for that project also?
Without seeing the damage, that sounds more like a fiberglass cloth / resin repair. Duraglass is good to fill voids (like between the flare and the body). Fiberglass is better to larger gaps without adding much weight. You would need to put some wood / foam as a form for the wet glass until it hardens.Very good details. Thanks for the thorough response.
Ok for that gash, You would take the flap wheel and clean up the whole area almost up to the stripe. Make a bevel around the cracks. Can you get behind that damage? Let's assume you can't. cut 4 layers of random direction fiberglass (HomeDepot) that are progressively larger. The smallest fits into the cracks in the hole. Just brush some activated resin all around and in the depression (that's not a hole...because there is material there you can use to support the wet fiberglass)...then place the smallest piece of glass in the depression. More resin till the glass is near clear. Then another layer. Finally the last two pieces are larger than the cracked area and into the depression you ground. Let it all dry. Flap wheel it flat. Use body plastic (not Duraglass) to smooth it all out. Switch to flat sandpaper (60 then 100 then 200 then 400 grit as all gets level and smooth) on a sandpaper block (to unsure it's flat). You will need multiple coats of body plastic.View attachment 22443
Here's that damage. It was a problem I was going to tackle another day (as I mentioned, I have many questions, but am trying to not post too many at a time).
But since it could be related, it might help me decide what products to be purchasing for that fender repair.
BTW, @Jim , and others curious on the story behind this one. I know this one FIRST HAND:
- New RV owner
- 34 foot class A
- Parked VERY close
- Quickly learned what "tail swing" meant...the hard way
