TheLooks
RVF 1K Club
- Jun 30, 2021
- Harrison, TN
- Winnebago
- 431C Minnie Winnie
- 31 ft
Most of the time only running lights are converted for a vehicle that has a 24v system.You said it was a Coleman Lite, but did not mention the model number. Could you add that so I can look up this unicorn?
Guess I need to reread this post! I thought he was looking for alternatives for what he had. 24volts is an excellent alternative.As I said, a unicorn. These kind of questions are better asked in forums that deal in exotic conversions, like the one I got into to study this a bit. There are people out there that have done some nifty things, but they are like you and live on the edge of what can be done. Not your typical camper people.
I was interested to read the negative views from well informed people on the conversion being done that was very similar to what Degnr8 wants to do. It is doable, it can work, but it requires adjustments to how you live in it and requires constant attention and care. In particular, that guy insisted he was going to us a DC air conditioner and he was told repeatedly it would not work. It simply could not produce enough cooling, even in a small van. We all learn from doing things and finding out for ourselves. Have fun experimenting!
The answer turned out to be much simpler than a unicorn trailer, and given the track record one this deal should have been the obvious one for me. The trailer has a 12V system and camping world just gave me the wrong batteryYou said it was a Coleman Lite, but did not mention the model number. Could you add that so I can look up this unicorn?
It's a bus conversion with a wheelchair lift. All I said was that the charging system was 24v. I'm sure most of it's dropped down to 12In post #7 he said the “rig” has 24 volt system but in post #1 he said its an E350. Never heard of a 24 volt E350.
just trying to understand - sounds like an interesting projectIt's a bus conversion with a wheelchair lift. All I said was that the charging system was 24v. I'm sure most of it's dropped down to 12
Good catch on that - I never looked at the picture but even if I had I probably would have missed that. I also think theres probably a fourth possibility.Yes, I agree Rich. As for the wrong battery, I was working on a 5th wheel yesterday and took a picture of the top of the 2 batteries. Both them said 24DC on them. They were 12v batteries. Actually, they measured 5.8v! I do not believe they gave you the wrong battery. SO I went back and looked at the meter you showed and you have selected AC volts not DC volts. So are you doing this intentionally? Just to see what people say? Or how little they know?
I still think the 24 refers to battery size and not voltage. Different size batteries in 12 volt also include 27 and 31.Yes, I agree Rich. As for the wrong battery, I was working on a 5th wheel yesterday and took a picture of the top of the 2 batteries. Both them said 24DC on them. They were 12v batteries. Actually, they measured 5.8v! I do not believe they gave you the wrong battery. SO I went back and looked at the meter you showed and you have selected AC volts not DC volts. So are you doing this intentionally? Just to see what people say? Or how little they know?
