Stuart W
- Nov 2, 2019
- London Aire 4595 FL SL605
- FL
- Cummins
- Jeep Wrangler
I do remember our dealer telling us that on the delivery as we ran thru the basic operation of the coach. Some times it is unavoidable. I would love to hear the practical engineering basis for the warning though. Just being told that its not good to do something is not good enough for me. If there is an actual and practical reason that the slide should not be stopped once it begins a cycle, someone should explain why.Unfortunately this hardly ever happened but in the later years it’s happening mine was a 23
One thing that came up from Newmar, you should never partially bring the room out and then bring it back in. They say that this creates undue pressure on the slide mechanisms.
I was wondering how the pinion gear would even be installed with the assembly in situ. It looks like it would have to be completely disassembled on a bench. It will be interesting to see what HWH will be willing to do for me on this for sure.In mine the sent the entire “arm” the part that bolts in at the top to the wall and the floor. Included cylinder, chains, rack etc. I think HWH has the ability to goodwill, maybe if you’re doing the labor that will sway them. Good luck. Ask for a new arm assembly
The synchronizer cylinder that can’t always equalize the pressures created when the travel is reversed in mid travel. This was my understanding of what was saidI do remember our dealer telling us that on the delivery as we ran thru the basic operation of the coach. Some times it is unavoidable. I would love to hear the practical engineering basis for the warning though. Just being told that its not good to do something is not good enough for me. If there is an actual and practical reason that the slide should not be stopped once it begins a cycle, someone should explain why.
When I asked HWH they said they didn’t know why it failed, my tech at HWH thought that Newmar’s were upgraded with a metal sleeve around the revolver because of the weight of the slide room. This turned out to be incorrectI’ll ask Frank about it in the morning and see what his understanding is of the practice.
Great up dateUpdate. I took apart the forward actuator system to see if I have a similar issue as what happened to the aft unit. There is unusual wear on the Stainless Steel washer between the pinion and the cylinder which I am concerned with but after sharing photos of the wear with the tech at HWH and they do not share the same concern. They will keep the notes in my file should any future issues develop that might require action so they may do more good will warranty work. They are sending me a new washer to install. Hopefully the damage to it happened in the short period the aft unit was failing causing some binding which should be corrected once I repair and adjust the system. I did note and report to them that there is grease on the pinion and smeared on the rack. According to the tech, there should be no lube at all on the assembly, period. I think someone at Newmar noticed an issue during delivery or final inspection and attempted to correct it with grease. The forward trim parts have been previously removed and reinstalled which would support my notion. HWH has no documentation of any trouble with the assembly reported by Newmar so who knows who did what to it.
I did get word that my new actuator assembly shipped on Wednesday so I should see it here early in the week and get back in business.
I know you would rather not have had the pleasure, but you have certainly gone above and beyond taking charge of this problem and I’m sure the results will far surpass that which could be gained by taking it to some local RV shop.Update. I took apart the forward actuator system to see if I have a similar issue as what happened to the aft unit. There is unusual wear on the Stainless Steel washer between the pinion and the cylinder which I am concerned with but after sharing photos of the wear with the tech at HWH and they do not share the same concern. They will keep the notes in my file should any future issues develop that might require action so they may do more good will warranty work. They are sending me a new washer to install. Hopefully the damage to it happened in the short period the aft unit was failing causing some binding which should be corrected once I repair and adjust the system. I did note and report to them that there is grease on the pinion and smeared on the rack. According to the tech, there should be no lube at all on the assembly, period. I think someone at Newmar noticed an issue during delivery or final inspection and attempted to correct it with grease. The forward trim parts have been previously removed and reinstalled which would support my notion. HWH has no documentation of any trouble with the assembly reported by Newmar so who knows who did what to it.
Well, the silver lining to the story I guess is now I will have a thorough understanding of the hydraulic system and know what to inspect for in the future. Part of the experience of owning boats and RVs and aircraft over the years has been working on them myself. If I did not enjoy that aspect of ownership, I would never have owned these things. I am happy that HWH is stepping up with the goodwill in providing the parts.I know you would rather not have had the pleasure, but you have certainly gone above and beyond taking charge of this problem and I’m sure the results will far surpass that which could be gained by taking it to some local RV shop.
Good luck with all that. Definitely beyond what I would tackle - I’m impressed. Are you out of warranty or did you just give up on the “experts”? Take some pics…My new slide actuator assembly showed up via UPS yesterday. Today I was able to get it mostly installed. Tomorrow I will finish it and a buddy is coming by to give a hand with syncing up the system. It takes two or three hands to do it safely and not damage things. The cylinders need to be extended and retracted several cycles detached from the chain rails to equalize and synchronize so the room extends and retracts evenly. This needs to be done with the elevator cylinders disabled so the room does not drop and break the tiles. This will be interesting. The coach has been down for five weeks now. crossing fingers that all will go well.
Interesting. I have not been there but have heard only good things about them. I guess it’s all in who you talk to and believe.I have heard such horror stories about the service guys at Demartini
