Question How did I kill two slides at once?
Did Newmar have you do a chassis disconnect to reset? I know that helped me when a slide would not go all the way out.
Thanks for the tip! I tried, but nothing good happened.
And...the verdict is in! The problem had absolutely nothing to do with running over the steel box. In the bay with the electric cord reel there's a relay-thingy labeled "DSSR" (for Driver Side Slide Rooms). And, there was a loose wire cleverly hiding behind a plastic cover. Reattached wire and just like magic, the slides work again! I can't help but remember that the Newmar tech I spoke with told me that all the slides were independent of one another. I owe the thanks to Geoff at Longhorn RV Repair in Niederwald, TX.
Well, that's good news. Glad the problem is solved. Thanks for the follow-up.
