RKins
RVF Expert
- Nov 15, 2019
- Sarasota, FL
- London Aire
- 40'
- Spartan
- 6CTA 8.3L Cummins.
- 2008 Jeep GC Overland
Having hundreds of thousands of miles in air suspended class 8 trucks, and fleets with multiple trucks with air suspension, I have NEVER experienced or heard of an airbag failure from over extention. Our application required dumping chip trailers on a hydraulic lift. It picks up the trailer and tips it straight up so the load slides out the back. When the trailer cleared the truck the suspension would jump straight up to the end of the shock. Multiple times per day. Again, not one failure. So the painfully slow lift of RV Jacks isn't going to cause airbag failure. A shock? Maybe if it was defective. The only bag failure I've experienced was a puncture caused by external force. Keep in mind some of these trucks had millions of miles on them.I’m headed to HWH to have an inoperative Active Air repaired. This morning I called HWH to get help with the system so I could at least make it to their facility. Because I was having problems with the AA system not keeping the air bags inflated, when parked I wanted to deploy the jacks without deflating the air bags as I have done numerous times in the past. The HWH tech was adamant that I must not deploy jacks without deflating the bags. He said I could very likely “pop a bag”. Is this actually possible? I’ve never heard this before and am not sure I believe it. Comments from the all knowing members please.
All the tires I've changed, I always put the jack under the axle, never have I jacked one up from the frame. Especially a loaded rig.Still trying to work the jacks/airbag information to a logical conclusion.
When a shop changes a tire, they place a jack under a solid frame member and jack the coach up. Never have I seen them dump the bags first. Isn’t this exactly the same as using the coach’s onboard jacks to raise the coach? What am I missing here??
Thanks so much! I'd hate to see someone just yry to help...That last sentence kinda narrows the field a bit. I’m still pondering this…..
The Dutch Star has independent front suspension and the front cannot be lifted except from under a frame point.All the tires I've changed, I always put the jack under the axle, never have I jacked one up from the frame. Especially a loaded rig.![]()
My Tiffin Phaeton also has independent front suspension. I place the jack directly under the ball joint at the end of the A arm under the spindle. The jack is lifting the ONE wheel rather than the entire corner of the coach. I DO put the front leveling jacks down solid in case the jack fails.The Dutch Star has independent front suspension and the front cannot be lifted except from under a frame point.
There is a warning on both sides of my front suspension saying not to lift from those areas.My Tiffin Phaeton also has independent front suspension. I place the jack directly under the ball joint at the end of the A arm under the spindle. The jack is lifting the ONE wheel rather than the entire corner of the coach. I DO put the front leveling jacks down solid in case the jack fails.
They may do that to keep someone from improperly placing a jack on the A-frame, that would destroy it. But lifting from the ball joint location is no different than the Coach sitting on the road.There is a warning on both sides of my front suspension saying not to lift from those areas.
And did you dump the air first? That’s what the OP is all about.When I got steering tires last time I put 2 of my 3" pads under the front Leveling jacks and lifted it for them they were like![]()
LOL
Nope end of the shocks is end of the shocks.And did you dump the air first? That’s what the OP is all about.
When you Auto Extend, the bags dump air automaticallyI did have all my air system checked for leaks at Freightliner this year when I had my annual service and no air bags were leaking. I believe most Jack auto level systems dump bags first but I’m not sure the main reason for that is to protect the bags but get the coach body lower to the ground. Manually dropping jacks can be done with bags at any fill. So, back to my main question, does it damage the bags if you deploy the jacks without dumping air?
My Encore AA system auto dumps my airbags prior to leveling. When I pull into our building I manually dump so the satellite dome clears.I’m headed to HWH to have an inoperative Active Air repaired. This morning I called HWH to get help with the system so I could at least make it to their facility. Because I was having problems with the AA system not keeping the air bags inflated, when parked I wanted to deploy the jacks without deflating the air bags as I have done numerous times in the past. The HWH tech was adamant that I must not deploy jacks without deflating the bags. He said I could very likely “pop a bag”. Is this actually possible? I’ve never heard this before and am not sure I believe it. Comments from the all knowing members please.
Just because this thread was revived, here is my take!My Encore AA system auto dumps my airbags prior to leveling. When I pull into our building I manually dump so the satellite dome clears.
