Onan 5500 generator, stops after a few seconds, shows code 41
JeffAndPam
Alabama
Fleetwood
Flair, 34R
34'
I have an Onan 5500 in a 2005 Fleetwood Flair (specs are in the image at the bottom).
When I try to start it, it starts up for a few seconds, then stops, and displays a code 41, which from the manual indicates:
"GENERATOR ROTATOR FAULT - Controller unable to sense field or output voltage"
BACKGROUND:
I last started it in January when outside temp was 17F. Was sluggish, but started. I hadn't run it since then. We've only used the RV once since then (one overnight, on shore power).
I just tried starting the generator over the weekend. The first few times I started it wouldn't start. I forgot that I had left the shore power plugged in. I unplugged the shore power and tried starting, but still get the same problem, and the code 41 above.
So two potential influences: 1) Not running it for a few months. 2) Trying to start it a few times while on shore power.
Any suggested things to try (other than testing the fuel pump, which was working)?
SPECS:
Code 41 is your key!
Due to field strength manipulation (regulation for a better output). Your generator has a commutator and brushes for the field (rotor). This could be a bad connection, bad brush contact, or a control board.
No matter, your generator has a shut down for this fault is my guess. You are going to need to trace the circuit to find that open.
A side note:
Not only have I been offered some of these Onan generators at no cost, but I have been unable to find anyone willing to take such when running! Messing with them in my environment, is simply not worth my time.
They are quality, old technology, that most feel are to expensive to keep running, for full time use.
The consensus is the modern inverter generators, not only have a cleaner output, but are also less expensive (fuel wise), to use when needed.
Good luck with your trouble shooting!!!
Thank you Kevin.
I'm learning (the hard way) I should start with simplest solutions first.
Given that, what do you think I should focus on first (and how)?
Generator Rotor Fault -Code 41 (Contoller unable to sense field or output voltage).
I would look at the brushes as Kevin suggested
UPDATE:
I just tried again, and this time see another code: 45.
So these are the two codes that have appeared:
41 - "GENERATOR ROTATOR FAULT - Controller unable to sense field or output voltage"
45 - "SPEED SENSE FAULT - Controller unable to sense quadrature frequency"
Given that, should I focus on the Controller? I see a few on ebay, perhaps purchase one that can be returned?
Or is there something simpler to start with?
I had an issue with ours…something about speed. I thought a new control board was in my future. Cummins couldn’t trace the problem with their laptop…decided to go inside. A loose screw. A screw in the intake would get sucked into the speed Governor and scramble the signal…so the unit shut down each time we started it.
Guess we got one manufactured on Friday….
Works now…hope they used locktite.
Chuggs makes a very good point! A simple loose wire or corrosion,can cause many electrical problems.
That said,the first thing you should check are electrical connections.
Your codes indicate there is no 115 being produced. That still leads me to no field! Check all connections leading to the brushes. Make sure water has not corroded them! Literally, if your field has no power, you will not get any output. No output the control will not be able to read the frequency!(that would be the second code 45)
Mind you, I am no expert on Onan generators. If you're model has a self exited field, you will find a run capacitor that energizes an Exciter coil. I don't expect you will find such an item, but if there are no brushes,you will. And that capacitor if bad would likely be the culprit.
Sound like a good start! TY
So I'm curious, can I do all this without removing the generator? I watched this video:
From that, I see the brushes are on the back side. He cut a hole in the side of his generator and inserted an access panel. I don't have room to the left of the generator like he does.
Also, i tried to find the control board, but am not sure where that is. I pulled the box where the starter switch is located and looked behind that, It wasn't there. I found this link:
Onan 5500 Generator Parts Breakdown
but couldn't see where the control panel is.
UPDATE: See next post.
UPDATE:
I've found two good videos to help with this:
and:
So now I have the info I need to get started...
The 95 bego I had had a tray I could slide out. I simply supported it when I slid it out. That was much easier than trying to get in places in didn't fit!
So I have the brushes removed, and I can see the rings. They look a little dark, so I'd like to go ahead and clean them.
I'd rather not order the special cleaning stick and wait for it. Can I use sandpaper for this? If so, what grit?
Update:
I've removed the brushes, they look good. Below is a picture of the slip rings, visible with the brushes removed. Unfortunately the camera left them a bit blurry. They look like they have a dark band on them. From what I've learned (this is all new to me), that doesn't seem good.
I know I can order a "slip stick" from "Flight systems", but rather than wait, is there a home-ready that can be done? Would like to get this back together today.
I saw one post that suggested Scotch-Brite pads. Also I've seen denatured alcohol mentioned.
UPDATE #3:
I managed to clean up the slip rings using Scotch-Brite pads. I no longer got a code 41.
Instead I started getting a Code 36: "ENGINE STOPPED FAULT - Engine stopped without command by controller", then listed such items as check gas level, secure spark plugs.
I fiddled with the spark plug lead wires, pushing them on securely, started again, now I get:
Code 45: "SPEED SENSE FAULT - Controller unable to sense quadrature frequency"
Quadrature is the forming of a sine wave used for timing,as the fault states. My thoughts are not timing but cycle count to determine frequency of the output.
I could be off on that assumption. It could be the spark tuning via the crank position.
First listed issue is still generator is not producing output. Seems the output is the signal for the governor.
Second possibility would be a sensor likely on the flywheel.
I think it Wise to call cumins onan about the source of the code.
UPDATES #4:
We just took it for a drive, stopped somewhere to test the levelers.
We also tried the generator. This time got the Code 41 again.
It seems to alternate between codes 41 and 45.
With that in mind, is there a possibility it could be the controller board itself?
How many hours on it? I would just take it to a reputable Cummins placeand have it serviced. One morning or afternoon - everything upto date and running smoothly.
It only has 300 hours on it. The nearest Cummins dealer is over an hour away. I was hoping to avoid that trip.
I'm considering pulling out the controller to get a controller number off of it, and see how much a new one is. It might be worth trying to put in a new one first.
BUT, others here are so much smarter about this than I am. I do appreciate all the advice.
If it was exercised every month from the time it was new, that is all it has been used in 19 years? If it were mine I would drive the hour and have a thorough service done on it. At that age it may need more stuff than you can find.
UPDATES #4:
Sorry! I am in the forest with marginal service. Long weekend always taxes service,so slow will be my response .
I think the board is potted so examination of the board will be a problem. The microprocessor is working or you would have no codes. There could be a bad solder joint, but I would not tell you to replace the board yet, I am not one to throw parts at something to fix the problem!
If you are, then buy a board! I think you will be throwing money away!
Look in the install manual and follow the 12 volt supply wires. Making sure All connections. Are solid on the 12 v+ + side. Then Make sure All groundings straps and busses/ground points are solid and clean.
There is something simple in the power to the armature circuit as to why it is not getting power.
Because I know what to expect, I would jumper maybe 6 volts to the brushes and see if the thing produced power. I might even use a lower voltage. That would likely give a voltage way out of tolerance, so the generator should be isolated to keep damage limited. You may find the field voltage in the trouble shooting section of a field manual.
The only damage it might cause is burn out the board you want to replace so bad. Have a meter on the output and be ready to shut her down.
One more time!!!
Disconnect from the coach if you follow this suggestion.
Thank you Kevin for your detailed reply!
I'll start here since that's simple enough.
One question: I recently purchased a product called DeoxIT, as it was suggested by other RV owners to use on electrical connections.
Would it be worth my time to apply that to all connections?
