- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
they already have permanent immigration check points along several highways and alongside those are typically scales check points for semi's, that infrastructure is already in place and will be what is used to enforce this.I seriously doubt CA is going to post law enforcement at EVERY road, highway or freeway that enters the state. Stopping and checking every RV, that would be impossible.
Scare tactics is all this is.
Yeah? I call BS because how many THOUSANDS of RV's and travel trailers go by these "checkpoints" every day?they already have permanent immigration check points along several highways and alongside those are typically scales check points for semi's, that infrastructure is already in place and will be what is used to enforce this.
I towed my 26ft Travel Trailer from CA to CO and back and got stopped by CHP both times at scales for a weight certification test to be sure I was within the tow rating of my vehicle.
this is another CA cash grab and they will do anything to grab that cash.
Not BS!!!Yeah? I call BS because how many THOUSANDS of RV's and travel trailers go by these "checkpoints" every day?
They are not going to stop recreational RVers for weight checks.
They do. not all, but those they think are at or over the tow capacity of their vehicles, I am very close, doesn't surprise me I was stopped.Yeah? I call BS because how many THOUSANDS of RV's and travel trailers go by these "checkpoints" every day?
SCOTUS has struck down that Traveler non-sense many times.Not BS!!!
Back in the day a cop drove by trucks and determined over weight, just by how the tires sung! Any suspect was routed to the scale. Today in motion scales
will do the job.
Border check points are only a means to stop you for many different mandate violations. Aircraft are what is used to find unsuspecting travelers!
Things will change drastically, when people realize the difference between the words driver and traveler!
If you did a survey on just these forum goers, they wouldn't know!!!
REGARDLESS of the CARB publication, or otherwise, CALIFORNIA does not have to worry about me crossing the border into their State!
I don't know how much more clear this could be? Diesel motorhomes not registered in California are EXEMPT! California cannot regulate diesel motorhomes registered in other states and especially those snowbirding from Canada.Well that's still not completely accurate. The CARB website states that motorhomes registered out-of-state "are only [exempt] during the first four years of Clean Truck Check implementation (2023-2027)". So both Freightliner notices were accurate some degree ... but they seem to be missing vital clarifying information.
