- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Same, I've never used spigot to flush, I also spray with bleach solution like @jaydee325I always make sure my gray tank is pretty full and use it to rinse after dumping black water.
Dump station water spigots are used for everything imaginable, and some unimaginable. Often in rapid succession.
CG water spigots have the luxury of a two-hour or so gap between check out and check in. That two hours affords the spigots the ability to forget how they were used. Therefore, clean slate.
What is the distance from the dump port and your spigot at your campsite? Is there code that mandates this distance?it’s the proximity of the hose to all the nasty stuff being dumped
No!What is the distance from the dump port and your spigot at your campsite? Is there code that mandates this distance?
There should be but we’ve all seen so many different configurations, including the water less than a foot from the sewer hookup that I’d say this is completely unregulated. Maybe in Ca where everything else is regulated…What is the distance from the dump port and your spigot at your campsite? Is there code that mandates this distance?
I think Calli is beautiful! Not enough to go there,but beautiful just the same! I have made a choice to avoid their regulations, I even think China would be proud when looking at how they have handled their population!There should be but we’ve all seen so many different configurations, including the water less than a foot from the sewer hookup that I’d say this is completely unregulated. Maybe in Ca where everything else is regulated…
I clean mine with a tank full of soapy grey water. No need to do anything more.
