Question How many amps does your DP PULL
@Joe Hogan did you determine what was loading your circuits?
In addition to the Oasis electric having a large draw, when lithiums are charging that is also another large draw. When our lithiums are charging they can pull 15+ amps at 120v. Since it is totally silent and not seen it can easily be forgotten.
We have worked through this issue. After some study on which and what is drawing, we shut down several items, exercising the Oasis diesel circuit for hot water, using only two of the a/cs ( not enough for the 105F temps,), etc
Load is much more reasonable.
I can easily draw 95amps just doing life in the coach. There is no way I can run all the appliances (washer, dryer, stove, dishwasher, microwave, 3 air, Oasis AC1/AC2, vaccum, floor heat, and battery charger).
A typical mid-day will have the washer/dryer going, Oasis AC1/2, 3 air, and various laptops, which will be pulling 70 amps peak. Make lunch on stove top while warming up something in the microwave and I will bump up quickly.
Right now I only have Air#1 running and very little load elsewhere.
Ok Chuggs, flog me if I am wrong. I am not the most electrically savvy, but I believe 50A shore power gives you 50A at 120V on each leg. You should have energy to spare. Beware it may not be as much on the generator, depending on its size (10kw = 83 A, 41.5 on each leg).
Well, although I cannot hold a candle to @Chuggs as far as knowledge and great explanations, it is correct that 50amp is 2 legs at 120v, for a total of 100amps potentially.
And the generator is (generally) less. Mine is 8k, or about 66amps.
Hope this helps
Rich
My 2019 DSDP vs the current 2022 LADP both consumed the same amount of energy, as they had the same options.
The 10kw generator could not power all of the devices we used when we where maxing out boon docking, so we had to adjust when we used certain devices. Not a big deal.
The 12,5Kw gives the same amount of available power (at sea level) as shore does, so we generally have no distinction on how we operate between Generator and shore.
You are drawing way too much power. Actually I am more concerned that your main breakers are not tripping. In my rig I can run both AC units and other appliances without tripping. My AC units each draw 13 amps each. This leaves 24 amps available for other items if you loaded to 100% of available power. While circuit breakers are built and tested to run at 100% of their rating they are listed to be applied at 80% of the handle rating. if you apply that rule that available current on a 50 amp service is 40 amps which in my case in practical applications leaves 14 available amps after you take away the 26 amps used by ACs when running.
Well,80 amps.
Ditto on the 12.5kw gen - we operate the same on gen as we do on shore power.
@Joe Hogan keep in mind you have Lithiums which can pull 300A for charging if your charger is not setup correctly. Be sure to review your charge settings.
I don't know any charger that would be able to deliver more than 50amp. Of course, 50amp would be quite a bit, but only would occur if voltage had dropped.
My point was simply, and may be completely off, is that LiFePO4 batteries can pull a lot of AMPS if given them unlike FLA/AGM batteries. I doubt it's a cause but it's new to a lot of us, self included and the charger must be configured correctly or it can use quite a few amps...I believe.
I understood what your point was.
I was attempting to add clarity that the batteries will take up to the charger MAX setting, but will never exceed the max setting.
To your point--Yes---if the charger is set to allow 20Amp of AC Load, then those batteries could take it all. They will not take 21 amps or higher...meaning it will not act like a dead short, but it will take everything you give it.
Hope that is clear as mud.
