Upgrading my House Batteries
Texas Clodhopper
Garden Ridge, TX
Ventana 4369
Longer daily
Cummins
2025 Jeep Gladiator
I'm not financially prepared to invest in a total solar package but I'm seriously considering upgrading my 8-230AH wet cell batteries to LiFePo4 batteries. The 12v LiTime 230AH batteries are high on my list. Should I get 4 to replace the 8 wet cell batteries? Bluetooth, heated? All the options make my head swivel. I know I will need other items to safely charge the LiFePo4 batteries using the engine alternator and maybe the genset, what else? I always read not to use the LiFePo4 as engine starting batteries so how about starting the genset? Ugh!
Be easy on me my friends, I don't know enough to ask semi-intelligent questions but all advice is welcome.
These are all good questions…. As far as how many amp hours to get, it depends on how much dry camping you might do. And remember you probably only have to replace half of your current wet cell capacity since you really only can use half of its stated capacity anyway. So 400Ah of lithium may be enough if you do not plan much boondcoking.
Bluetooth may be nice….and depending on where you live and how cold it gets there, heated could be an option. But keep in mind you probably only have to worry about heated batteries if you need to charge them in the cold (below freezing or so). They can be used (discharged) when cold…. You could also heat the battery compartment and save money on heated batteries. Mine are not heated…have not found I needed it.
And I believe the gen gets started from the chassis battery.
A LiBim or dc to dc charger will protect the alternator. I have used a LiBim for 3 years without issue.
I hope this helps.
Keep the questions coming.
Rich
Just to add to the excellent reply from @Richpatty - first off, you don't have to have solar because you have LiFePO4 batteries. I initially did solar for a reason, storage without power, it was a great learning experience, but it has been rarely used over the years. We'll see how that plays in now with my LiFePO4 setup as that will influence me to play with the solar, but most of us big rig'ers, IMHO, are typically on shore power 98.26% of the time. The LiFePO4 batteries will last longer, have a longer warranty, and save a lot of weight. In the end, they will probably cost the same as AGM as you'd replace AGM at least twice in the lifespan of the LiFePO4 I believe.
Now it comes down to amp hours. That's how you figure out your capacity. And like I designed with my new setup, I can add four more batteries if I choose. We'll see how my 4 x 330's work out. Keep in mind you get 50% of your battery AH capacity, you'll get 90% of LiFePO4 so that math comes out to a less overall AH requirement. It's more about your budget at this point.
One thing to consider with LiFePO4 is external BMS or internal BMS, i.e. what protects the batteries. My Victron's require an external BMS, Battleborn for example has an internal BMS. I'd take a good look at SOK's and other brands. There are a lot of offerings on the market, look at warranty, etc.
I don't want to overwhelm you, keep the questions coming as Rich said. Black Friday deals are ahead. It's a good time to buy, doesn't mean you have to change them now.
Thanks, guys.
1. Wire in series or parallel?
2. What about cabling?
3. @Neal, do you have 4 - 300 ah batteries?
4. I've watched several of Will Prowse YouTube videos and reviews of different brand batteries.
5. Did you make your cables? @Richpatty , I live in the San Antonio area and since 2007 and have never been to an area where I needed to winterize.
6. This past year we did considerable boondocking and plan to do similar this next year.
7. I need to confirm my Mangum MS2812 is compatible with lithium charging.
4 x 330's - they have come down in price quite a bit since I bit that bullet.
Wow...there are several hours of reading and re-reading to be done. Unbelievable write-up.
Thats for sure! :)
Put my install to shame...
Let me put it this way, he has almost twice as much invested in his solar system as I paid for my first home. :)
@Richpatty, do you have a post somewhere with a more realistic @Texas Clodhopper budget? :unsure:
LOL. Sure. Here is my Lithium thread from 2022.
Look to post #41 on the thread for my install.
Rich
Thanks.
Typically a battery used to crank has a cranking anp spec. And With enough lithium batteries you could get the needed cranking amps
So how does an EV manage excess loads? Well the "way", to handle regen, and acceleration is to include a supper capacitor! This moderate investment can drastically reduce the battery bank requirements!!! Note that this will not change the required AH to make it to the next charge cycle.
Okay now, that didn't include "solar" so you have to deduct the price of your Big Wheel.
Clodhopper, I replaced my 8 6v batteries last January with three 206 amp hour SOK heated bluetooth batteries. I lowered my battery weight by almost 400#. My magnum 2812 would come on and recharge the batteries every six to seven days when plugged in in the barn. You do need to "close up" your battery bay to keep moisture out. My generator starts just fine off of the house batteries. I just recently removed one of the batteries and the genny still starts fine. You will need to change the settings in the 2812 and probably be happier if you get an ARC-50 to replace the RC-50(plug and play)
Thanks, guys.
Your house batteries are 6 volt, so they are wired in series/parallel to create a 12 volt "battery bank". LiFePO4's thatbyou will be looking at are going to be 12 volt - so wiring in parallel.
