MarkMaxPayne
- May 24, 2023
- Beaverton, OR
- New Aire 3543
- 36'
- Spartan
- Fiat 500 Turbo
Unfortunately, I don't as I hit the workshop and picked through a jar of "leftovers". It was a common size though as I recall. The washers that worked best had a hole slightly larger than the hinge pin grommet that the retaining ring (or twisted wire others have suggested) slots into. This way the diameter of the washer hole is too small for the ring to flex and squeeze through the hole. The overall diameter of the washer just needing to be larger than the hole in the door hinge as that then sits on top of the washer vs directly on the ring.What a great idea. Do you remember what size the washers are? Thanks for the information.
Best,
-Mark
