MOD Storing a telescoping ladder above bins in storage bay
MarkMaxPayne
Beaverton, OR
New Aire 3543
36'
Fiat 500 Turbo
I've been storing a telescoping ladder on top of two plastic storage bins in the driver's side bay behind my inverters in my 2023 New Aire. The problem is that those are my storage bins for keeping all things black tank and additional fesh water seperate. Anytime I wanted to set up or break down the ladder is in my way.
I had my son, who is taking welding classes, add a couple of small tabs to a piece of 1/8" thick angle iron that I picked up at Home Depot. I measured the outside width of the bay's star foundation uprights to the back of the bay, cut the angle iron, cut two tabs, had him weld them to each end to make the angle iron now look like a 'T', drilled mounting holes, then painted it black with some rust preventing paint.
The first picture shows the angle iron mounted with the flat edge on top, to act as a small shelf, as viewed from the opposite bays on the passenger side. You can see where I had to remove the aluminum angle iron that holds the edge of the clear acrylic panels that protects the electrical items. This was then cut down to two brackets to create room for my ladder support to mount flush to the star foundation uprights.
Once that was mounted in place for the top of the ladder to lay down on, I then mounted some velcro based straps to the top of the bay near the doors where each of the ladder's two uprights are.
Now I can easily store my ladder up against the roof of the bay out of the way. Both bins can be removed and stored without worrying about the ladder.
When I want to retrieve and store the ladder I can also leave the storage bins in place. However it is easier if the first bin is removed as the bin furthest to the back can stay in place and act as a ramp to leverage the top of the ladder against when positioning on and off the newly added ladder support angle iron.
Hopefully others find this helpful. Note that I twisted off two self tapping stainless steel screws even though I predrilled the holes. Only use the very best if you don't want to go through the frustration I did dealing with crappy/cheap screws.
Best,
-Mark
Thanks for sharing. I'm looking for ideas on how to store the ladder and yet not be in the way.
Have you tried just laying it on top of the generator and securing with a 1" strap? I have had mine there for over a year with no problems.
Jealous! On the New Aire there isn't enough clearance over the generator either... Doesn't slide out, up high on the chassis rails...
Best,
-Mark
Thanks for the idea. I'll see if this works when I'm at the RV later this week. Did you secure with a 1" strap to the top of the generator or did you secure to something else? Wondering if you drilled a hole in the top of the generator or used a self tapping screw? Concern would be when putting in the screw you have bad luck and hit something. Maybe it will be clear what to attach to when I'm at the RV.
I have thought about opening up the generator a finding a spot where I could drill a couple of small holes the "S" hooks on the strap would just fit in. I have got out of the mood to do that since it has carried just fine for a year the way it is. I have one strap near the front that hooks in the slotted holes in the tray. I just snug the strap doe on the ladder'
Thanks for the idea!! Makes for efficient use of storage. A couple of straps will hold the ladder in place.
I store mine on a HD wire shelf installed above the Dometic frid/freezer. I store other misc items there as well, telescopic pole, extendable snow brush, lg umbrella.
