How would YOU escape a fire in your RV?
bpaikman
Lake Jackson, Texas
Ventana LE 3436
35 feet
Cummins 340 hp
One time when we were traveling on I-10 from Baton Rouge toward Texas, on one of the many miles of elevated highway over swamps, we noticed a motorhome smoking in the distance, on the eastbound bridges. By the time we passed it, which could only have been a minute or two, it was engulfed in flames. We couldn’t stop, the bridges are not accessible to each other.
We never did find out what happened.
But it did make us think. What if you were in an accident (heaven forbid) turned over onto the side to block the main exit. Do you think you could access the alternate exit in seconds? It seems to me it might be a good idea to carry a sledgehammer or some way of breaking out at the front of a motorhome. Thoughts, or better yet, plans? We might be able to slither out of the driver side window…. Maybe ……I haven’t tried it lately. 😆
One of the reasons we like our Superstar.
Driver door, passenger door, mid entry door passenger side, and escape window driver side bedroom.
The other thing I keep handy and accessible is a knife that has a seat belt cutter as part of it - just in case. Hopefully never need but you never know. It also has a post on one end that will shatter window glass if needed.
We also have a SuperC and ours has a split windshield. In addition to having the 2 doors on the cab, either side of the windshield can be forced out by a good shove/push from the inside.
The safety aspects of more egress and front protection is one of 2 key reasons we chose a super c.
We ordered a drivers door on teh CanyonStar for this reason. If the vehicle is laying on its passenger side all exits were blocked. Unfortunately, this is not an option for the DSDP.
We have a exit window driver's side BR window in our DSDP
Traveling I-5 north in Oregon last week, we witnessed a southbound older 1990s Bounder lose control and end up on the patio side on the dirt. Main door and three (3) large windows blocked. We saw one person exiting from the driver side bedroom emergency exit window. After seeing this, we discussed our emergency exit options as we continued north. On our coach, we have up to six (6) options depending on the nature of the emergency.
Many things to consider, and practice. I made a video on this subject, a couple years ago, after Andrew Steele's fire. His, too, was a total loss and...thankfully...they were driving at the time.
I got a lot of questions on this topic, focused around being asleep, in the back of the coach, etc.
Yes, a window breaking tool might be a good thing to have in those cases where you have to break a non-exit window. Most coaches have multiple points of egress.
However, a lot of people don't consider protecting themselves during that panicked exit. Knowing how "most" people sleep, chances are you're not going to be prepared, in the slightest, for broken glass, slithering through a sharp broken window frame, and THEN jumping down onto the ground which also may be hazardous for bare feet.
I covered having a "go-bag" in an accessible bay AWAY FROM POSSIBLE FIRE origins, so that it can be grabbed quickly as you get away from a burning coach. Having SHOES, cover garments, GLOVES, goggles, and whatever else you can think of, including dog collar/leashes may prove to be a true life-saver if the environment is harsh.
Good that you're thinking about a plan. Hopefully this gives you some more thoughts that can be a part of that plan. Just remember to rehearse it over and over until it becomes "instinct" over panic!
yes we have same thing - and we were considering with the mental shock and confusion, and probable injuries after a crash like that, would we even be able to crawl to that escape hatch in the back, in time to escape a fire, if it were in the front?. What if it were in the back?
And visualizing our motorhome lying on its side, we realized we're not going be walking down the aisle to the back, we'd be crawling over furniture and who knows what debris.
I'm ordering one of those seatbelt cutter sledgehammer things.
And driving even more slowly.
EXCELLENT - thank you so much! and yes I was aware of Andrew Steele's fire. Saw that video some years ago and it shocked me. I don't recall if they found out what caused it.
Where is this video?
I pulled it off to the "Private" mode after parts of it became outdated, as well as stirring up a bit of "controversy & speculation" that detracted from the intent of the video.
I will trim it a bit and release it for you; not sure if it will give you any more info that I mentioned already:
Thank you! can't overdo safety reminders
